midstar Posted September 28, 2004 Report Posted September 28, 2004 Where is the front air bag sensor on my car, and what does it look like. I can't seem to find it. I have taken off my front end to fix it (I hit a truck). I haven't seen it. I have found something that looks like the outside air temp sensor, but my friend says that it is the air bag sensor. I haven't seen any yellow plugs or wiring so I would like to know where it is at since the air bags didn't go off. Quote
DiscoStudd Posted September 28, 2004 Report Posted September 28, 2004 It's a "box" about 1 1/2" cubed that sits behind the grille (or in the GP's case, behind the nose.) It's mounted to the front side of the radiator core support and has a warning sticker on the top of it telling you not to fuck with it. Judging by where it is on my Regal, you have to remove the plastic shroud from between the header panel and core support to expose it. Not exactly sure whether or not the GP is the same, but it should be in the same location... Quote
midstar Posted September 28, 2004 Author Report Posted September 28, 2004 Thanks for your information. That is where I thought it would be at, but this has been my second accident and they haven't gone off. I will try and look again to see if I can find it. Quote
digitaloutsider Posted September 28, 2004 Report Posted September 28, 2004 96 5-speed?! :shock: Fuckin' sweet, man! Quote
DiscoStudd Posted September 28, 2004 Report Posted September 28, 2004 Thanks for your information. That is where I thought it would be at, but this has been my second accident and they haven't gone off. I will try and look again to see if I can find it.FYI, the module for the airbags is located under the passenger side front seat. I would probably suspect that before I'd suspect the crash sensor, but it could be either one. If your Air Bag readyness light flashes when you first start the car and then turns off, the system is working properly. If the light stays lit, or doesn't even light up (or flash) when you first start the car, then there's most likely a glitch in the system somewhere. I'd suspect possible tampering if the airbag light never comes on when you start the car. Either that, or there was a problem with it for so long that the light just burned out from staying lit all the time... Quote
supreme_style21 Posted September 29, 2004 Report Posted September 29, 2004 ^^ What he said. Or else the accident hasn't been severe enough to cause the bags to go off. I've seen cars in accidents where one would assume the air bags would have gone off and I've seen cars in such minor accidents with blown bags. Quote
midstar Posted October 3, 2004 Author Report Posted October 3, 2004 I think that the place that originaly fixed my car from the first accident removed the sensor. My front clip was smashed where it should of been. Thanks for all your information! PS Oh yah it is a manual GTP it took me 2 months to do Quote
Heza Posted October 3, 2004 Report Posted October 3, 2004 I think that the place that originaly fixed my car from the first accident removed the sensor. My front clip was smashed where it should of been. Thanks for all your information! PS Oh yah it is a manual GTP it took me 2 months to do wanna do my car? Quote
