Gearhead43 Posted September 28, 2004 Report Posted September 28, 2004 I need advice on: 1. Removing the 13 mm bolt under the Rear Exhaust header holding the rear of the turbo to the header. ( I've removed 4 ) 2. Do I need to detach the crossover from the exhuat mainfolds to be able to remove the turbo unit from the crossover? 3. Any ideas how to disconnect the oil feed line (Still rounding off even with a flarenut wrench and backup wrench.) Quote
