dohc v6 Posted September 25, 2004 Report Share Posted September 25, 2004 i need to get the pump out of the car and i cant get the metal hose off the pump. what do i do. it is not the rubber one. Quote Link to comment Share on other sites More sharing options...
Guest TurboSedan Posted September 25, 2004 Report Share Posted September 25, 2004 use a flare nut wrench (line wrench). i'm not sure what the size is off-hand. Quote Link to comment Share on other sites More sharing options...
dohc v6 Posted September 25, 2004 Author Report Share Posted September 25, 2004 when i try that it just turns and if i do it any more it will bend the hose. Quote Link to comment Share on other sites More sharing options...
JoroCorona Posted September 25, 2004 Report Share Posted September 25, 2004 So bend the hose and buy a new one. Chances are if the pump is bad its pumped some nasty shit into that hose and its all clogged up. Just get a new hose. Quote Link to comment Share on other sites More sharing options...
paulo57509 Posted September 25, 2004 Report Share Posted September 25, 2004 when i try that it just turns and if i do it any more it will bend the hose. You need to use two wrenches; one on the hose fitting (a flare nut wrench) and one on the PS pump fitting. Quote Link to comment Share on other sites More sharing options...
dohc v6 Posted September 25, 2004 Author Report Share Posted September 25, 2004 got it thanks. it was just very tight and did not bend the hose Quote Link to comment Share on other sites More sharing options...
