supreme_style21 Posted September 25, 2004 Report Posted September 25, 2004 This was a pain in the ass to remove from the column and I can only assume a pain in the ass to reinstall. Do I NEED it hooked up? Quote
DaveFromColorado Posted September 25, 2004 Report Posted September 25, 2004 that's the ignition lock cable, you can bypass it if you want, but just make sure you're able to shift it still. without that part, you can shift out of park when the keys are out of the car - not really a benefit if ya ask me. --Dave. Quote
supreme_style21 Posted September 25, 2004 Author Report Posted September 25, 2004 Cool. I say screw it. It doesn't get hooked up. Quote
DaveFromColorado Posted September 26, 2004 Report Posted September 26, 2004 just make sure you can shift outta part without it, I can't remember which direction the cable travels to unlock the unit, otherwise just rig it up so it's always free. --Dave. Quote
EurosportZ34 Posted September 26, 2004 Report Posted September 26, 2004 honestly i don't ever remember that cable being there when i did mine... Quote
Brian P Posted September 26, 2004 Report Posted September 26, 2004 keep it or bypass it. Never got the chance to install in my '90 Cutty. I'd say do it just so your install is complete OEM. It's maybe a half hours worth of work. But if your interior's already back together then forget it. Quote
supreme_style21 Posted September 26, 2004 Author Report Posted September 26, 2004 keep it or bypass it. Never got the chance to install in my '90 Cutty. I'd say do it just so your install is complete OEM. It's maybe a half hours worth of work. But if your interior's already back together then forget it. How do I install it? When I removed it, I was blindly working with it, so I'll be damned if I know how it goes back in. The interior is back together for the most part, but I still need front seats, so its together enough so that I can drive the car. On a side note, how do I remove the column shifter? Hopefully I don't need a new column. I'm thinking I'll grab a new cluster and dremel the fawker off. Quote
DiscoStudd Posted September 26, 2004 Report Posted September 26, 2004 I think you will need to get the ignition switch from a console shifted car to be able to hook it up properly. Just from my quick observations of both of my cars (1 column shifted, one console) when I had the signal switches out in each, I'm not sure the column shifted ignition switch had the provision to run the interlock cable... Quote
supreme_style21 Posted September 26, 2004 Author Report Posted September 26, 2004 I think you will need to get the ignition switch from a console shifted car to be able to hook it up properly. Just from my quick observations of both of my cars (1 column shifted, one console) when I had the signal switches out in each, I'm not sure the column shifted ignition switch had the provision to run the interlock cable... I think I felt that secondary cable up in the column.. But the more I think about it, I don't think it is. If I have to start swapping ignition switches, I'll just ghetto rig it. The chance of someone else owning this car is next-to-none, so as long as I know how it works and it looks OEM, I'll be content. Quote
Brian P Posted September 26, 2004 Report Posted September 26, 2004 there's 2 tiny screws that hold that black housing onto the top of the 88-93 column. you'd have to remove the 2 column bolts closest to the steering wheel and loosen the 2 near the firewall (or just remove those too, even easier) remove the top column plate, and it sits under there. My description of where it exactly would go is worthless without pics. Quote
supreme_style21 Posted September 27, 2004 Author Report Posted September 27, 2004 Yeah I know the general area of where it came from... I took it out of a Monte Carlo that had been rolled hardcore, so I had all I could just to get IN the car to get all this stuff out, much less wiggle myself underneath the column to see where it came from. If I get some ambition one day, I'll start tearing it apart again. Quote
grandprix9292 Posted October 29, 2004 Report Posted October 29, 2004 if its not hooked up the key switch might not let you turn the key back to the acc mode so just watch for it Quote
