what size tire should I go with if I get the 17x7 rims, I want to keep the speedo accurate!
on 17x7 tire, i have 225/45/r17 tires, but the diameter is alittle smaller than the stock tire so my speedo is off by about 2-4mph? I know its off slightly though, anywho, i found 225 plenty wide bu maybe try 225/50/r17? Something with a slightly bigger sidewall.
nick
on 17x7, i have 225/45/r17 tires
that is the same size that are currently on my cutty...
What size was originally on your car?
225/55R17 = 26.7" diameter
225/60R16 = 26.6" diameter
225/55R17 is the closest match for a 7" wide rim if you had 225/60's before. 235/50R17 (26.3") is the closest match if you had 215/60's before (26.2"). I don't think it's a good idea to go to 245's on a 7" wide rim.
