tloftus Posted September 21, 2004 Report Posted September 21, 2004 I'm looking into the parts needed to do an ECC upgrade. Following a search it looks like I need the HVAC controls, inside temp sensor, outside temp sensor and the fan control (also known as an HVAC Power Module). Can anyone give me some pictures or a good description of where these parts are located? Alldata doesn't help much. Thanks! Tom Quote
Guest Posted September 21, 2004 Report Posted September 21, 2004 pre '94 (or maybe '93?) Cutlass I assume? HVAC controls are the unit itself with buttons, display, etc. Inside temp sensor is a little square thing in between the passenger side vents below the glove box. Brian P will know a lot more about this... Quote
jeremy Posted September 22, 2004 Report Posted September 22, 2004 I have the dual electronice climate control in my '97....I hear it would be a bitch to upgrade from a standard climate control though.... Quote
5speedz34 Posted September 22, 2004 Report Posted September 22, 2004 I know its been done on the older interior cuttys 88-94. I heard its worse on the newer ones. Quote
