The reset button, thats what im asking about. If i trace away from where TV cable attaches to the TB, theres this small round plate, maybe 2" side, that the cable goes through. At that plate is where theres a clip of some sort which is where I was assuming the adjustment is done at. If i had my digicam with me id take a pic but i dont.
  • Like 1
the square button on "top" of that, yeah. It's hard to push, may need to push down with like a 3/8 extension bar
  • Like 1
  • 2 weeks later...
Hey Brian, I tryed the adjustment this weekend but couldnt get the clicks. I rocked the motor forward to simply things. I pushed the little square button down while pulling the metal linkage cable that attaches to the TB but no luck. Id pull it and as soon as i let go it'd go back to the same spot. What am i missing?
  • Like 1
it's so hard to explain it on the internet, if you were here It'd take me 10 seconds. To reset the cable (like if you accidentally overadjusted it) you press down that button, grab the black cable SHEATHING that's "behind" the button (opposite the TB) pull that away, towards the P/S, you'll hear clicking. Then release the button, manually open the throttle linkage all the way (will hear clicking again). To ADJUST the cable so the tranny shifts lower than stock, grab the tip/end of the cable (not the sheathing or clip or button, the actual cable) with pliers and slowly pull until you hear more clicking. You don't need to press on the button at all. Usually 3 clicks does it good. Does this make any more sense? If not I may have to take a pic, however I no longer have any 440-T4 cars around...
  • Like 1
Alright, so pull the tip with the TB closed (normal off position), and i dont need to press the button down?
  • Like 1
Now thats a big arrow, lol. If i cant get the adjustment to work ill put my stupid hat back on and come back to you :lol:
  • Like 1
