White93z34 Posted September 18, 2004 Report Posted September 18, 2004 how hard is this to change? would a bad one account for a car missing/stumbleing? edit: its for a 1992 3.4 car. Quote
Scr00ge Posted September 18, 2004 Report Posted September 18, 2004 When my crank sensor went bad, the car wouldn't even start. Scr00ge Quote
Guest Anonymous Posted September 18, 2004 Report Posted September 18, 2004 They told me it was the crank sensor when the 95 blew the timibg belt pulleys. Its not hard to reinstall i beleive. Quote
Canada Posted September 19, 2004 Report Posted September 19, 2004 Its on the back of the block. SUPER easy if you have a manual transmission instead of the ghetto booty automatic sitting there. Just make sure the sensor doesn't break (mine did)..............if it does, you have to drop the pan......which means dropping the cradle...... Quote
White93z34 Posted September 19, 2004 Author Report Posted September 19, 2004 well gp90se and i were talking and he thinks its not the CPS in said car, its also an auto. what it does, it has one hell of a time starting then will stumble and miss do that for a while then die, could that be the cps? Quote
Canada Posted September 19, 2004 Report Posted September 19, 2004 After hearing whats going on....... What sort of fuel pressure are you getting? I don't know the exact spec of the top of my head.......but it should be 35 pounds or so....with a increase of X amount with a snap of the throttle.....anyone have access to a service manual or AllData right now? I'm thinking it could be a weak pump.........or a fuel pressure regulator not raising pressure enough. Typically, a CKP sensor failure shows up as a cranks/no start or engine dies after hot, won't restart until cool (mine did this). Quote
White93z34 Posted September 19, 2004 Author Report Posted September 19, 2004 no idea i just looked at this car friday in the pouring down rain so i didn't have any time to troubleshoot it going back monday to look at it again though what sort of tool do i obtain to check fuel pressure levels? Quote
Canada Posted September 19, 2004 Report Posted September 19, 2004 A fuel pressure gauge. Sears or any auto parts store carries them.....fairly cheap and is an excellent tool to have. It simply connects to the shrader (sp?) valve on the fuel rail....there should be a black cap over it. Quote
White93z34 Posted September 19, 2004 Author Report Posted September 19, 2004 ok so i'm gona assume that cps is getting ruled right out? if so good. i'll be sure to go back there and check the fuel pressure. if thats in spec what else would you think it is? Quote
Canada Posted September 19, 2004 Report Posted September 19, 2004 If fuel is okay.....then its either compression, air's ability to enter/leave .......or ignition. I would aim towards ignition....based on how the motor is acting up....you might have a TPS or MAP sensor acting weird....at this point, I doubt it. I'd first take a look at your wires.....carbon tracking/tears/corrision.....then plugs........then you can move onto coil packs and the ignition module............and then the crank sensor........and then the PCM. I know this sounds anal....but I HATE shotgunning parts. I should of first asked.........are there any stored codes in the PCM? Quote
digitaloutsider Posted September 19, 2004 Report Posted September 19, 2004 there should be a black cap over it. Silver on most of our cars, actually Quote
White93z34 Posted September 19, 2004 Author Report Posted September 19, 2004 mines black i think... the guy who owns the car claims he just replaced the wires, spark plugs and coil packs no idea if any codes are stored, that will bo one of the things i check when i go back Quote
Regal_GS_1989 Posted September 21, 2004 Report Posted September 21, 2004 I've had problems like this on an 88 regal with a 2.8. If it missfires on startup, especially if it is humid outside, you most likely have a cracked coil pack. If it stalls after start up and the SES light comes on, it could also be a bad emissions hose hook up. (Little black hoses comming out of the throttle body) Quote
WhiteOut Posted September 22, 2004 Report Posted September 22, 2004 This is probably a tad late, but a bad CPS should result in the car having about a 1:6 chance of starting. Basically the PCM doesn't know what cylinder is where, so there a 1:6 chance it gets it right, but even then it doesn't know the "exact" position so it will probably run like crap. Quote
White93z34 Posted September 22, 2004 Author Report Posted September 22, 2004 it dosen't matter now anyhow i'm not buying that pile Quote
Canada Posted September 22, 2004 Report Posted September 22, 2004 there should be a black cap over it. Silver on most of our cars, actually Are you on crack? Both of my cars have black caps. All of the newer GM's are black. I'm actually trying to think of a silver fuel cap on a GM vechile...........I can't. Quote
