TeeJay3800 Posted September 17, 2004 Report Share Posted September 17, 2004 Now that my plenum is finished being sanding/rubbed/polished, I want to pull the front valve cover so I can give it the same treatment. Should I replace the gasket while I'm at it? Is there any difference between valve cover gaskets or are they all the same? Quote Link to comment Share on other sites More sharing options...
no1kicker Posted September 17, 2004 Report Share Posted September 17, 2004 Might as well replace it while the valve cover is off. Felpro is a good gakset brand. Quote Link to comment Share on other sites More sharing options...
Robby1870 Posted September 17, 2004 Report Share Posted September 17, 2004 Yes, replace it, even though its rubber. They stretch over time, and if you put an old one back on, it will more than likely leak. They are cheap anyway Quote Link to comment Share on other sites More sharing options...
PeNZ Posted September 17, 2004 Report Share Posted September 17, 2004 replace it yes Quote Link to comment Share on other sites More sharing options...
per0781 Posted September 18, 2004 Report Share Posted September 18, 2004 replace it yes dont forget to put some black rtv where the intake manifold makes contact with the head Quote Link to comment Share on other sites More sharing options...
