Robby1870 Posted December 28, 2002 Report Posted December 28, 2002 Does anyone know if the 3.1L's Chevy put in small trucks in the late 80's are similar to my FWD 3.1L?? There is a lot of performance stuff for the Chevy motor. Also, where could I find stock camshaft specs?? And, I would like to do a cam swap, any ideas or thoughts?? Thanks Quote
cutlassdude96 Posted December 28, 2002 Report Posted December 28, 2002 you could try http://www.60degreev6.com Quote
Vegeta Posted December 28, 2002 Report Posted December 28, 2002 The intakes and exhaust wont work because those older blocks were iron heads. You can use the rocker arms and the cams and pistons (but the CR will not be the same on the aluminum heads so get the measurements). Quote
