maybe2fast Posted September 15, 2004 Report Posted September 15, 2004 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7922289889&category=33741 what do you guys think? Quote
White93z34 Posted September 15, 2004 Report Posted September 15, 2004 anyone who shells out $160 for that is a bloody idiot. Quote
Stevo Posted September 15, 2004 Report Posted September 15, 2004 With a name like wassupmyhomies how can anyone NOT trust him. Quote
99RegalGS Posted September 15, 2004 Report Posted September 15, 2004 Well that thing flows 150CFM and the 3.4 flows ~400CFM at redline. So unless you have a very small engine it isn't going to do jack. EDIT: The 3.4 would actually flow around 340CFM at redline. That's assuming an 80% VE. Quote
maybe2fast Posted September 15, 2004 Author Report Posted September 15, 2004 I saw it on E-bay so I thought I would just post it... Quote
jeremy Posted September 15, 2004 Report Posted September 15, 2004 Well that thing flows 150CFM and the 3.4 flows ~400CFM at redline. So unless you have a very small engine it isn't going to do jack. if both your numbers(probable) and his numbers(doubtful) are correct , wouldn't adding ~37% more air help performance?......although I could be an idiot too....it wouldn't be the first time.... Quote
sl3196 Posted September 15, 2004 Report Posted September 15, 2004 I think it would be a big restriction in the intake. Quote
digitaloutsider Posted September 15, 2004 Report Posted September 15, 2004 Well that thing flows 150CFM and the 3.4 flows ~400CFM at redline. So unless you have a very small engine it isn't going to do jack. if both your numbers(probable) and his numbers(doubtful) are correct , wouldn't adding ~37% more air help performance?......although I could be an idiot too....it wouldn't be the first time.... That's what I was thinking.. Quote
99RegalGS Posted September 15, 2004 Report Posted September 15, 2004 if both your numbers(probable) and his numbers(doubtful) are correct , wouldn't adding ~37% more air help performance?......although I could be an idiot too....it wouldn't be the first time.... It would help, but to a point. once the engine wants more than 150CFM that leafblower will start to create a restriction. 150CFM on a 3.4 is about 3000 rpm. So under that it would actually help a little. But after 3000 rpm it's usless and will start to cause a loss in power. Quote
jeremy Posted September 15, 2004 Report Posted September 15, 2004 It would help, but to a point. once the engine wants more than 150CFM that leafblower will start to create a restriction. 150CFM on a 3.4 is about 3000 rpm. So under that it would actually help a little. But after 3000 rpm it's usless and will start to cause a loss in power. the way I read it was that it created 150CFM (highly doubtful, but that is his claim), so in theory you should add that 150CFM to what is already being taken in, correct??? Quote
sl3196 Posted September 15, 2004 Report Posted September 15, 2004 But when the engine is sucking in more air then the fan can flow, it would just restrict the flow. Quote
midnight rider Posted September 15, 2004 Report Posted September 15, 2004 all that thing is is a squirl cage blower like most cars have in their heater boxes. It will help a little, but not enough to make it worth what they are asking for it. If you look hard enough thru jcwhitney, you'll find something simular to that for Volswagons for their heaters..... lol Quote
Baddflash Posted September 16, 2004 Report Posted September 16, 2004 Looks like a vaccum to me. I'd say that besides being a restriction to the intake it probably couldn't make any boost and most likely wouldn't improve overall performance. It may help at low rpm by improving air/fuel mixing but other than that it'd be a waste of money. Quote
Bruticus Posted September 24, 2004 Report Posted September 24, 2004 I always thought that thing was a scam. Quote
conley3.1 Posted September 25, 2004 Report Posted September 25, 2004 Well, sonyman87 has an eRam "electronic supercharger" on his LQ1 Lumina, along with some other things, and he ran a 15.1 1/4. But that's not an eRam, that's a generic one. I don't think it could move enough air to properly feed the engine above like, 4000 rpms. It would probably just be a restriction past that point. Quote
Andrew Posted September 26, 2004 Report Posted September 26, 2004 that type of thing has been around for a while. i swear i read somewhere on a forum or something that a guy bought one and did dyno runs. he gained a whopping 1 HP! :shock: whoo hoo im gonna go buy one! Quote
GPRACER Posted September 27, 2004 Report Posted September 27, 2004 Would probably work well on the fireplace in my living room, that's about it. Quote
Jcrow Posted September 27, 2004 Report Posted September 27, 2004 That CFM rating is probably with no pressure. As soon as it sees a little pressure the cfm will go way down! That type of fan can only make pressure in "inches of water" not even 1 psi! Quote
