brianteel Posted September 15, 2004 Report Share Posted September 15, 2004 anyone have a shop manual for a 89 cutlass that has the digitail dash info in it Quote Link to comment Share on other sites More sharing options...
Brian P Posted September 15, 2004 Report Share Posted September 15, 2004 if you're looking for pinout locations, check the main site Quote Link to comment Share on other sites More sharing options...
brianteel Posted September 15, 2004 Author Report Share Posted September 15, 2004 i am more looking for the C100 pinout and to know what powers it Quote Link to comment Share on other sites More sharing options...
Dirty Rockstar Posted September 15, 2004 Report Share Posted September 15, 2004 The 2 pink/black wores power it.. All the other stuff is add on accessory power feeds to tell the UB3 what to do with itself.. Also ground it when powewring, obviously.. lol Quote Link to comment Share on other sites More sharing options...
brianteel Posted September 15, 2004 Author Report Share Posted September 15, 2004 is it a signal from the ECU or is it something else...the issue is with a swap. oi=ne guy i know did it but i dont know how and i have not seen him around in a long time Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted September 15, 2004 Report Share Posted September 15, 2004 If you're trying to get the tach to work, it gets its signal from the ALDL. Orange wire in the ALDL connector. Quote Link to comment Share on other sites More sharing options...
brianteel Posted September 15, 2004 Author Report Share Posted September 15, 2004 what i am looking for is how to get the thing to light up. there has been issues aftet the wiring is done it does not work at all. The tach, does it not use the same information as the analog type dash. does it use a signal from the ICM? Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted September 15, 2004 Report Share Posted September 15, 2004 Check the pinouts and make sure you have it wired correctly. I've had no problems firing up a Cutlass digital gauges cluster on the floor of my spare bedroom, so there's not anything special that it needs. Just power and ground to the right pins. Be aware that the pinouts for the digital cluster nowhere resembles that of the analog cluster. Almost every wire has to be moved. Â No, it does NOT get the tach signal from the ICM. It gets it from the ALDL. Â I'm not sure why the big difference in pinouts and where they get the tach signal, but that seems to be the case with all digital clusters made by Nippon Denso. Quote Link to comment Share on other sites More sharing options...
Dirty Rockstar Posted September 15, 2004 Report Share Posted September 15, 2004 I havent even lit mine up yet!! LOL! I might do that today.. How would I go about it? I have the harness plug if I should just Strip the power and the ground.. Use a wall oputlet? Quote Link to comment Share on other sites More sharing options...
brianteel Posted September 15, 2004 Author Report Share Posted September 15, 2004 i am not adding the cluster in to the car. i am doing a swap in cutlass that has one and i want to make sure i can get it working. I saw the pinouts do you have the corrisponding circuit numbers. that would be even bigger help. do you also have the pinouts for the C100 connector on the firewall Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted September 15, 2004 Report Share Posted September 15, 2004 I don't have either available to me right now at work. I might have them at home, but I'd have to check. Â If this is an L67 swap you're talking about, the tach will not, and cannot work. Â Only 2 ways I know of to make it work. 1. Piggyback the old ECM and feed it just the minimum inputs it needs to convert the ICM signal to ALDL data. 2. Build a custom microcontroller that converts the ICM signal to ALDL data. I know of one person who has done this, goes by "*********" on the forum. Quote Link to comment Share on other sites More sharing options...
brianteel Posted September 15, 2004 Author Report Share Posted September 15, 2004 yeah he is the guy that in know of but i have not heard from him in a long time Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted September 15, 2004 Report Share Posted September 15, 2004 He's on MSN Messenger and AIM a lot. Quote Link to comment Share on other sites More sharing options...
brianteel Posted September 16, 2004 Author Report Share Posted September 16, 2004 what is his sn Quote Link to comment Share on other sites More sharing options...
Baddflash Posted September 16, 2004 Report Share Posted September 16, 2004 I havent even lit mine up yet!! LOL! I might do that today.. How would I go about it? I have the harness plug if I should just Strip the power and the ground.. Use a wall oputlet? Â I hope you're not asking if you should run your dash of house power, are you???? 12v devices don't take well to 120v, so that'd be a no. Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted September 16, 2004 Report Share Posted September 16, 2004 what is his sn  ********* or ********* Quote Link to comment Share on other sites More sharing options...
Brian P Posted September 16, 2004 Report Share Posted September 16, 2004 okay he drank  the punkenstein is on right now! Quote Link to comment Share on other sites More sharing options...
brianteel Posted September 16, 2004 Author Report Share Posted September 16, 2004 mkay, he drank? the punkenstein is on right now!  ??? Quote Link to comment Share on other sites More sharing options...
Brian P Posted September 16, 2004 Report Share Posted September 16, 2004 Meaning he is signed onto AIM :shock: Quote Link to comment Share on other sites More sharing options...
okidedrak Posted September 16, 2004 Report Share Posted September 16, 2004 maybe you guys shouldn't post my info so openly on the forums?!? Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted September 16, 2004 Report Share Posted September 16, 2004 Your sn is the same on here, it's not exactly private info! Quote Link to comment Share on other sites More sharing options...
okidedrak Posted September 16, 2004 Report Share Posted September 16, 2004 well reflect on this If you are in a crowd at a concert/show/whatever and each person in that crowd has a name tag how many people would be interested in finding more about you or in the worse case decide to stalk you? What about if you are brought on stage? Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted September 16, 2004 Report Share Posted September 16, 2004 I've edited out the very important anonymous person's sn from my responses. Quote Link to comment Share on other sites More sharing options...
Brian P Posted September 17, 2004 Report Share Posted September 17, 2004 I too edited okiedrak's screen name from my posts. Quote Link to comment Share on other sites More sharing options...
okidedrak Posted September 17, 2004 Report Share Posted September 17, 2004 thx for making me look like an obnoxious and unsociable freak for no reason all this thread ended up being about me?! For everyone who reads it, I'm a very non important person, ignore me!! Brian and Shawn, msg them for all your w-body needs, they know it all! Quote Link to comment Share on other sites More sharing options...
