LarryMartin830 Posted September 14, 2004 Report Posted September 14, 2004 well i am going to get a turbo and all the stuff i need to change my 3.1 to a 3.1 turbo would i be able to just bolt on the turbo stuff its from a GP 3.1 turbo would my 3.1 take it and if it will for how long? and no its not for a w-body Quote
DaveFromColorado Posted September 14, 2004 Report Posted September 14, 2004 ... keep the boost low, and intercool it, and it should last for a long time... --Dave. Quote
LarryMartin830 Posted September 14, 2004 Author Report Posted September 14, 2004 ... keep the boost low, and intercool it, and it should last for a long time... --Dave. can i run stock boost? Quote
DaveFromColorado Posted September 14, 2004 Report Posted September 14, 2004 I'd try to keep it down, unless you're upgrading everything, computer, injectors and all. I'd run the wastegate directly to a vacuum source on the manifold so it'll stay wide open come 6ish lbs of boost. I know stock boost is somewhere between 7.5lbs and 8.5lbs, I can't remember which. --Dave. Quote
LarryMartin830 Posted September 14, 2004 Author Report Posted September 14, 2004 I'd try to keep it down, unless you're upgrading everything, computer, injectors and all. I'd run the wastegate directly to a vacuum source on the manifold so it'll stay wide open come 6ish lbs of boost. I know stock boost is somewhere between 7.5lbs and 8.5lbs, I can't remember which. --Dave. well i am getting the computer TURBO VACCUM LINES INTERCOOLER & PIPING COMPUTER O2 SENSOR WILL BE ON THE TURBO ALREADY CROSSOVER PIPE DOWN PIPE also get the injectors? Quote
DaveFromColorado Posted September 14, 2004 Report Posted September 14, 2004 Yes, injectors too - I believe they are higher flowing then the stock 3.1 - also the fuel pressure regulator is different (lookin' at part numbers) --Dave. Quote
LarryMartin830 Posted September 14, 2004 Author Report Posted September 14, 2004 Yes, injectors too - I believe they are higher flowing then the stock 3.1 - also the fuel pressure regulator is different (lookin' at part numbers) --Dave. ok Quote
gp90se Posted September 14, 2004 Report Posted September 14, 2004 TGP injectors at 22#, stock 3.1 are 19# what vehical is this going into, I know the turbo mount on the tranny wont clear in older N bodys Quote
LarryMartin830 Posted September 14, 2004 Author Report Posted September 14, 2004 TGP injectors at 22#, stock 3.1 are 19# what vehical is this going into, I know the turbo mount on the tranny wont clear in older N bodys my 90 Z24 Cavalier Quote
DaveFromColorado Posted September 14, 2004 Report Posted September 14, 2004 humm.. I wonder if that'd all fit in the J-body - if there's trouble because of the mounting in the N body's it may be dificult. I think the two share the same trans mount towards the top. I know the J-bodies have that crappy mount there tho. --Dave Quote
Vegeta Posted September 14, 2004 Report Posted September 14, 2004 stock 3.1 injectors are 16.6# Quote
R Dubya Posted September 14, 2004 Report Posted September 14, 2004 you're going to need the fuel pump too.. those injectors won't do any good if they can't get enough fuel Quote
LarryMartin830 Posted September 14, 2004 Author Report Posted September 14, 2004 it will fit theres alot of people that have done it Quote
DaveFromColorado Posted September 14, 2004 Report Posted September 14, 2004 don't forget to take pic's of the whole process - it'd be cool to watch/follow along with. --Dave. Quote
