Keyless entry
I was looking at buying a stock keyless entry box and fobs for my car. My car is a 95 and so is the box. Now my car did not come factory with keyless entry that I know of. Will it still have the keyless entry plug under the rear deck so I can plug in the box and use it?
Did you check for the programming wire in the trunk? It's a a wire with a connector on the end that doesn't plug into anything. If your car has that it has keyless.
Also the keyless entry box may not be on the rear deck. It could also be below the rear passenger side window. That where it was on my Regal.
And the fobs are interchangable between the years . They will work as long as they are the square type and have the trunk button seprerate from the lock and unlock buttons.
the plug in mine was under the rear deck, (also sorry that I haven;t gotten you any pictures yet, as I have worked 14 hours today and am too tired to do it right now)
