Pic Request......ALDL Connector
I am looking for a pic of the ALDL connector, specifically the orange wire that needs to be cut to install a GP DIC.... thanks in advance....
Well assuming you'rs is a '96-'97 then, it's technically an OBD-II connector. Going with that same assumption, I hope you some how managed to track down a '96 GP DIC, cause otherwise it isn't gonna matter if you find the connector or not. The older ones won't run off of OBD-II data.
well mine is a '97....so do you know what color wire that I will have to splice into???
