Guest Anonymous Posted September 13, 2004 Report Share Posted September 13, 2004 If I put an OBD II engine in my 92 GP, and related ECM, would an OBD II HUD work in the car as well? just an idea I had. Quote Link to comment Share on other sites More sharing options...
slick Posted September 13, 2004 Report Share Posted September 13, 2004 Just get the engine running in the car first. Then worry about any HUD's. Also, I'm pretty sure an OBD 1 HUD will work, but I can be corrected if i'm wrong. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 13, 2004 Report Share Posted September 13, 2004 well i was asking to see, if i put and OBD II engine in, will my stuff still work, and would a newer hud be usable? no need to flame. Quote Link to comment Share on other sites More sharing options...
kfahn Posted September 13, 2004 Report Share Posted September 13, 2004 FYI: I don't think that that was a flame, just a friendly suggestion. Quote Link to comment Share on other sites More sharing options...
Guest TurboSedan Posted September 13, 2004 Report Share Posted September 13, 2004 well i was asking to see, if i put and OBD II engine in, will my stuff still work, and would a newer hud be usable? no need to flame. there is no such thing as an "OBD II engine"....only OBD II engine management. you can run the 3.4 DOHC engine on an OBD I ECM + memcal or an OBD II PCM. if you get a newer 3.4 DOHC engine just keep your existing OBD I ECM/memcal and wiring harness. Quote Link to comment Share on other sites More sharing options...
slick Posted September 13, 2004 Report Share Posted September 13, 2004 That's how mine is ran. 93 harness and ecm, 95 engine. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 13, 2004 Report Share Posted September 13, 2004 ohhhh.. I thought the engines were specifically OBDII or so. Im still unsure if I want an n/a 3800, 3.4, or an exisiting rebuild. Quote Link to comment Share on other sites More sharing options...
digitaloutsider Posted September 13, 2004 Report Share Posted September 13, 2004 If you swap to an engine that has OBD-II management (3400, etc.), you'll have some major problems getting your HUD, DIC, and various other nifty electronics to work properly. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 13, 2004 Report Share Posted September 13, 2004 If you swap to an engine that has OBD-II management (3400, etc.), you'll have some major problems getting your HUD, DIC, and various other nifty electronics to work properly. Thats what i figured. So if i took say a 3400 and plugged it into my OBD I managemant doo-hicky, would everything still work? Quote Link to comment Share on other sites More sharing options...
rudefyet Posted September 13, 2004 Report Share Posted September 13, 2004 If you swap to an engine that has OBD-II management (3400, etc.), you'll have some major problems getting your HUD, DIC, and various other nifty electronics to work properly. Thats what i figured. So if i took say a 3400 and plugged it into my OBD I managemant doo-hicky, would everything still work? Yes You'd need a custom chip though Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 13, 2004 Report Share Posted September 13, 2004 the wonderful world of dead car ownership. Quote Link to comment Share on other sites More sharing options...
sl3196 Posted September 13, 2004 Report Share Posted September 13, 2004 the wonderful world of dead car ownership. Then fix it! Quote Link to comment Share on other sites More sharing options...
94CutlassSLCoupe Posted September 14, 2004 Report Share Posted September 14, 2004 Really, the engine choice is up to you. I would definately keep the OBD-I stuff with the Memcal (no 3100 OBD-I stuff) Basically, all the engines have their strengths and weaknesses (below is just my opinion) 3.4 DOHC - Originally in 1st gen W-bodies, Highest Performing, Highest cost for replacement parts, hardest to work on. 2.8/3.1 MPFI - Run forever, in most 1st gen w's up to 94, not too bad to work on, replacement parts are cheap, you can probably get an engine for a song 3100 - Faster than a MPFI 2.8/3.1 by quite a bit, some parts are slightly more expensive, slightly easier to work on in most things. 3400 - Good swap in engine, will require custom calibration if not replacing a 3100, may need some 3100 1st gen W-body parts to install, more hp than the 3100. 3800 L27 (tuned port) - fairly easy to put in, came in 1st gen regals, run decent but only make ~170hp, you'd be better off installing a 3400. 3800 L36 (Series II), good swap canidate, but not any faster than the 3.4 DOHC...harder to put in than the 3400, makes 200hp 3800 L67 (series II supercharged), makes real good power, mods are easy to come by, not any harder to put in than an L36, requires premium gas, gets worst gas mileage, you will be ridiculed by some. You'll note i didn't put the 3.1 Turbo engine in here...the chances of finding one are pretty slim. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 14, 2004 Report Share Posted September 14, 2004 well my reasoning for a series2 3.8 is this... my parents have one in their 96 bonneville. damn that is one good, strong engine. they've put 120k on it without any engine problems- just ruitine maintance, and it still runs like new. Very solid, IMO, and easier to work on. The 3.4 would be the cheapest to swap in, but with it comes the typical troubles of 3.4 ownership that we all enjoy. I want whats best for my car and whats best for my wallet/atm... this car needs to run for a looooong ass time, and i cant go broke fixing it either. Like I said, when i get it fixed, that car is staying with me forever. Of course i'll get something newer along the years, but that baby is garage material... Quote Link to comment Share on other sites More sharing options...
94CutlassSLCoupe Posted September 14, 2004 Report Share Posted September 14, 2004 Run for a long time? I'll put money on the 2.8 Multi-Port lasting the longest, the 3.1 multi-port second, followed by the 3100, then either the L27 or L36 3800, 3400, then L67 Supercharged, and finally, the 3.4. If properly maintained and not beat to hell, they will all last pretty darn long...if you started with a new engine and changed the oil @ 3000 miles (and did the timing belt on schedule on the 3.4), I'd bet the 3.4 would make at least 130k, and all the rest should make 150 if not 200+ One thing to look at is parts for the 2.8/3.1/3100 and both the 3800 engines are everywhere in junkyards. Lots of good parts can be had for very cheap. Quote Link to comment Share on other sites More sharing options...
brianteel Posted September 15, 2004 Report Share Posted September 15, 2004 most of the HUDs dont have anything to do with the engine management system. they should all work in all cars (GM atleast). for the DIC you have to use the corisponding engine management (OBD1 or 2) because they use computer signals to run them. for what motors are the strongest L67 has the strongest bottom end. as for how long it last it all depends on what you do to it. 3.4 DOHC is high maintence but is till a good motor if maintained 3100 blows head gaskets and intake gaskets those are my experences. Quote Link to comment Share on other sites More sharing options...
PeNZ Posted September 15, 2004 Report Share Posted September 15, 2004 3100 blows head gaskets and intake gaskets Not in any of my experiences, and ive owned 3 60° v6's. Iron rwd 3.1. FWD 2.8, and now my 3100. No headgaskets or intake gasket probs for me. Quote Link to comment Share on other sites More sharing options...
rudefyet Posted September 15, 2004 Report Share Posted September 15, 2004 The turbo 3.1's have been known to handle 18psi on the stock bottom end Quote Link to comment Share on other sites More sharing options...
94CutlassSLCoupe Posted September 15, 2004 Report Share Posted September 15, 2004 I've seen a lot more 3.4's needing head gaskets than anything else... Mostly, people don't change their coolant and that is why the gasket goes bad. I've also never heard of a big problem with any of the 60 degree v's breaking the cranks or throwing rods. the 90 degree motors seem to spin rod bearings occasionally, especially if they have overheated. I have personally replaced an intake gasket on a 90 degree v6 (3300, same design as the l27) that only had 49k on it. Quote Link to comment Share on other sites More sharing options...
BurneroftheRice Posted September 15, 2004 Report Share Posted September 15, 2004 cant he also put in a series one 3.8 supercharged from the early SSEi? i think that is OBD I. it doesnt have as much hp as the L67 but it might be easier maintence wise then the 3.4 dohc and has more hp then the 3.1 Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 15, 2004 Report Share Posted September 15, 2004 All this engine stuff is so confusing for me. all I know is both of my 3.4 suck ass. I bought my 95 Gt from some old lady. she washed the car, but i doubt that she did any other meaintance, which may be why i had so many repairs to do within the first few months. The lady i got the petty from babied that car for 12 years, was religious with maintence, but her timing belt pully failed on a 10k old belt and is the current cause of my problems. Unless you can service the 3.4 yourself, theres not much you can do but empty your wallet and pray. I have nothing against putting a 3.4 back into the petty, as it would be nice to keep the car original and all. But i also want something that will be easy to maintain, last a while, and still have balls. If i coukd get a brand new 3.4 in there i;'d be happy, but I can;'t afford it. And i'm told a rebuild on the existing will just open up a can of worms. I was given an offer to deign websites at 1 grand a pop. Maybe that can pay for my repairs. Quote Link to comment Share on other sites More sharing options...
sl3196 Posted September 15, 2004 Report Share Posted September 15, 2004 3100 blows head gaskets and intake gaskets Not in any of my experiences, and ive owned 3 60° v6's. Iron rwd 3.1. FWD 2.8, and now my 3100. No headgaskets or intake gasket probs for me. I've never had head gaskets go on a 3100. The intake gaskets did though. Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted September 15, 2004 Report Share Posted September 15, 2004 OBD2 HUD? The only HUD that runs on serial data is the ones in the 04 Grand Prix. Putting one of those in is financially unrealistic, especially for someone who hasn't yet even been able to afford fixing the engine! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 15, 2004 Report Share Posted September 15, 2004 Gnat, I was aksing if my current gadgets would still work on an OBD II engine or if i would have to change them or something. Quote Link to comment Share on other sites More sharing options...
sl3196 Posted September 15, 2004 Report Share Posted September 15, 2004 Why don't you get your car fixed before you worry about this stuff? Quote Link to comment Share on other sites More sharing options...
