Guest Gp crazy Posted September 11, 2004 Report Posted September 11, 2004 well it's a GP with a crappie 3 speed tranny 125-c it has reverse unless i step on the gas! then a clunck most of the time but lately no clunck. fluid is clean and the filter is new. also long shift points step on gas i get to 40-45 that's first shift 70-75 that's 2nd shift? engine is screaming at these points. any help would be good thanks (: Quote
GP1138 Posted September 11, 2004 Report Posted September 11, 2004 well it's a GP with a crappie 3 speed tranny 125-c it has reverse unless i step on the gas! then a clunck most of the time but lately no clunck. fluid is clean and the filter is new. also long shift points step on gas i get to 40-45 that's first shift 70-75 that's 2nd shift? engine is screaming at these points. any help would be good thanks (: I'd check fluid, vaccuum lines, and then prices on rebuilt transmissions. In that order EDIT: I'd also throw a bottle of Trans-X or Lucas Tranny Fix in there, just to see what happens. Can't hurt anything. Quote
WhiteOut Posted September 12, 2004 Report Posted September 12, 2004 If your 1-2 shift is iffy (clunky and sloppy) too then you've probably got a fried band in the transmission, and that means rebuild. And frankly I'm going to guess that it will cost more than the car is worth. Quote
mihela816 Posted September 12, 2004 Report Posted September 12, 2004 Reverse goes out a lot on 3 speeds. Those are the normal shift points. Quote
gp90se Posted September 12, 2004 Report Posted September 12, 2004 i think its that tranny that has a sticky reverse valve, toss is a bottle of lucas and it should go away Quote
