3100 Belt Tensioner Replacement
The belt tensioner is junk on my 3100 (with 15,200 miles on it)...just flapping in the breeze at idle making my car run a little bit warmer than it should.
How hard is it to replace? Its like a $40 part which isn't that bad and I can see it.
Any brands I should stay away from? I'm currently looking at a Dayco.
Thanks!
Its supposed to move a little at idle to help keep the belt tight as the engine varies rpms. You may just need a new belt if its moving a lot
Just don't loosen the bolt on the tensioner with the belt on! I did this in my smarter :roll: years. Yah I broke it. As for replacing it just remove the belt and then the tensioner. Then when putting it back on I think there is a little part you have to match up. Pretty easy to do.
looks like the belt is at the replace line although the tensioner does move a bit side to side (not in the direction it would with the belt installed). Looks like it may have enough tension though.
