Running Lean
topless94style
I have been getting a SES light all summer, but its more frequent now. It used to only come on for a few seconds on the freeway, but now it comes on every time i drive the car. After driving for a little while, sitting at a light, the idle is poor, moves between 400-700rpms. Went to auto zone, got the code, dont remember the number, but it was a lean condition on a bank of cylinders. Since then, i have noticed my mpg drop 2-3mpg. O2 sensor? I put in a new O2 sensor last fall when this same sort of thing happened, only last fall it was a bad intake manifold gasket; which i replaced and it fixed all my problems. Havent found a vac leak, dont think its the O2, and im hoping its not another gasket leak.
Any ideas as to what this could be?
I dont think an o2 sensor would only cause one bank to lean out, since its outputs goto both banks.
Thats why i dont think its the O2, plus id be pissed if it failed in under a year anyway. I saving up right now for a new head gasket set, so i can put on my new heads, and fix that bastard oil leak. Hopefully this will also fix whatever is causing this problem.
I was going to say the same thing, she sounds like the injectors are sticking...
have you ran some seafoam / fuel injector cleaners through it?
I ran seafoam at the beginning of the summer. I went to the track on friday, and i THINK this problem is causing my car to be....well....horribly slow. Atleast i hope so, and my car really isnt this slow :lol:
10.62@68mph in the 1/8.
whenever my car would start to run a little lean, I would run some 103 through it, seemed to always get things cleaned up and working back to normal. :D
