93GTP Posted September 10, 2004 Report Posted September 10, 2004 Does anyone know if the newer style alternator (94+) will fit my '93 gtp? My alt. has died on me and I want to upgrade to the newer, more reliable one. However, I'm guessing that the plug on the wiring harness is probably different. I know I can simply compare the 2 alts when I head out to the rebuilder's, but I was wondering if anyone can answer my question beforehand. Has anyone done this? Quote
White93z34 Posted September 10, 2004 Report Posted September 10, 2004 as i recall, its the same thing. Quote
DiscoStudd Posted September 10, 2004 Report Posted September 10, 2004 I assume this is what you have now (seeing as you have a 93) This is the CS130: And this is what you want. This is the CS130D: I'd say find a car with a 3.4 that has the CS130D, take all of the brackets and the plug. Wire up the plug to your car's harness, bolt up the brackets and the alt and away you go! Also check out this place: http://www.alternatorparts.com/ They might sell adapter plugs so you won't have to hack your harness... Quote
Guest Anonymous Posted September 10, 2004 Report Posted September 10, 2004 93GTP, could yoyu supply us with ext. and int. pics of your vehicle? Thanks. Quote
THe_DeTAiL3R Posted September 11, 2004 Report Posted September 11, 2004 Okay, so the alternator on my 88' would fit on my 95?? Just wondering if I part it out.. Quote
93GTP Posted September 11, 2004 Author Report Posted September 11, 2004 Yes Disco, you are correct. But I still don't know if the plug on my 93's harness will plug into the CS130D, or even if the CS130D will bolt in the same way (although I'm pretty sure it does). I guess I'll find out for sure when I pull mine out and head out to the rebuilder. Quote
99RegalGS Posted September 11, 2004 Report Posted September 11, 2004 if you want I can snap a picture of the bracket on my 96 engine. Quote
