WhiteOut Posted September 10, 2004 Report Posted September 10, 2004 I finally got around to fixing the "custom" squeak my cars rear end has been making for a month now. I jacked her up to find that one of the rubber end caps for the leaf spring was gone and the other was kinda squashed and rapped around the very tip of the leaf spring all half assed like, it had also been worn though and was about twice its original size due to wear. Gee, I wonder why my rear end squeaked? Anywho I went looking for the Moog Chassis part (part no. K6544) and I couldn't find it so I went to NAPA and got their brand instead, it ended up costing a mere $9.25. Anywho the install was pissing me off at first since I couldn't get the leaf spring to go up far enough to allow me to slip the part in. I ended up having to use a floor jack to get the rear off the ground and then use a bottle jack with a piece of 2x4 cut into a wedge on the leaf spring itself so that I could get enough leverage on the leaf spring to slip the part in. The damn trailing arm makes getting a jack in there a tight fit so the wedge was essential during the install. Once I had everything figured out it may have taken all of 10 minutes to complete both sides. The ride quality over bumps is improved greatly, and I no longer have the embarassing squeak every time some one moves in my back seat, or when I hit a bump, or brake or move down the road. Kick ass. Quote
94CutlassSLCoupe Posted September 10, 2004 Report Posted September 10, 2004 Good Job man...glad you got that fixed! Quote
Justin Posted September 10, 2004 Report Posted September 10, 2004 Awesome, I definitely need to do that to my CS too, is it $9.25 for both sides, or just one? Quote
tloftus Posted September 10, 2004 Report Posted September 10, 2004 I did my cutty about a month ago -- changed rear struts just for that damn leaf spring problem. Oh well I guess -- new rear suspension. Glad it worked good for you. Tom Quote
WhiteOut Posted September 10, 2004 Author Report Posted September 10, 2004 Its $9.25 total. You get a pad for both sides. I wish my car cost $9.25 to fix every time it broke. Quote
Brian P Posted September 11, 2004 Report Posted September 11, 2004 did the pads look like the OEM rubber ends, or were they the pads that sit on the knuckle, like the MOOG ones? Quote
WhiteOut Posted September 11, 2004 Author Report Posted September 11, 2004 The pads were exactly like the Moog ones judging from the drawing on the Moog advertisement. They're poly pads about 3x2.5x.75 (a rough guess, I didn't actually measure). Quote
Brian P Posted September 12, 2004 Report Posted September 12, 2004 If you could throw a napa part # at me I'd be very appreciable Quote
WhiteOut Posted September 12, 2004 Author Report Posted September 12, 2004 No problem, kinda pertinent info I suppose... Napa Part No. NCP2746544 Moog Part No. K6544 Quote
DiscoStudd Posted September 24, 2004 Report Posted September 24, 2004 I just found the pad on the driver's side of my Regal was completely wasted, so I'm going to be making the trip to NAPA tomorrow. I understand from what's been posted that you have to place both sides of the car up on jackstands (I'd assume to take all of the tension off of the spring) and use the jack (with a small block of wood) to jack up the leaf a tiny bit to slide in the new bushing. Okay, my question is, do you have to remove the wheels and shove the old bushing out the other side, or can you leave the wheels on and scrape the bushing out towards the middle of the car? Follow me? I just don't want to spend any time removing the wheels if it's un-necessary, that's all... Thanks for the post about this, cause I was suspecting my struts were bad at first... Quote
WhiteOut Posted September 24, 2004 Author Report Posted September 24, 2004 I only had to remove one of my wheels. I also had to use a hammer and a long ass screw driver to tap that one side in. The other side however slipped in quite nicely from the rear without any need to remove the wheel or "coax" it. It will pretty much depend on how close you can get the jack to the end of the spring when putting leverage on it. Quote
