Dirty Rockstar Posted September 9, 2004 Report Posted September 9, 2004 I got my All Data runnin for a 92 Lumina.. Same setups as mine.. just ABS functions aree there.. Now, there are 3 tan/white braking system leads.. The connections at D14 and D13 are listed as "Optional".. What do they do? The Cutlass I pulled my cluster from donly has the one tan/white lead.. Im gonna run just the wires I got tomorrow to "See what happens.." But Im curious asa to what else these could go to.. Thanks! Quote
Baddflash Posted September 11, 2004 Report Posted September 11, 2004 Do you have the pinout for the cutty dash? Did you have the base or guages cluster? If you had the base you'll need to run a wire for the tach, That is unless the cutty gets all it's data from the aldl. :? I'd just hook up what wiring the Lumina has and hope enough of it works that the rest doesn't matter. Not sure, really cool idea though. I have a diagram I made of the lumina guages pinouts if that'll help. Quote
