no1kicker Posted September 9, 2004 Report Share Posted September 9, 2004 Is this considered the water pump gakset? Mine's leaking and I need to know what to ask for at the parts desk. :oops: Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 9, 2004 Report Share Posted September 9, 2004 Water pump outlet gasket. But I'm not sure if you'll find one. I used silicone on mine. Holding up good. Quote Link to comment Share on other sites More sharing options...
WhiteOut Posted September 10, 2004 Report Share Posted September 10, 2004 Just use RTV sealant. Its cheap and available plus it works great. Quote Link to comment Share on other sites More sharing options...
R Dubya Posted September 10, 2004 Report Share Posted September 10, 2004 The gasket it only a few bucks and worth it if you don't want to take it back apart. I got mine at Advance for less than $3.. Quote Link to comment Share on other sites More sharing options...
94CutlassSLCoupe Posted September 10, 2004 Report Share Posted September 10, 2004 isn't that the location of the thermostat too? Quote Link to comment Share on other sites More sharing options...
Guest TurboSedan Posted September 10, 2004 Report Share Posted September 10, 2004 no, the thermostat is on the other side under the waterneck, right next to the oil fill cap. Quote Link to comment Share on other sites More sharing options...
Heza Posted September 10, 2004 Report Share Posted September 10, 2004 thermostat bypass pipe o-ring. cheap at dealership. Quote Link to comment Share on other sites More sharing options...
rudefyet Posted September 10, 2004 Report Share Posted September 10, 2004 I just used silicone Quote Link to comment Share on other sites More sharing options...
Heza Posted September 10, 2004 Report Share Posted September 10, 2004 I just used silicone why? when you can fix it correctly for $3 if that. Quote Link to comment Share on other sites More sharing options...
THe_DeTAiL3R Posted September 10, 2004 Report Share Posted September 10, 2004 I used RV sealant stuff WITH my gasket when I changed the waterpump... that biatch will NEVER leak!! isn't that the location of the thermostat too? No but I there is a bleeder screw on top of that on my 3100 (I forget about my 2.8) Quote Link to comment Share on other sites More sharing options...
midnight rider Posted September 10, 2004 Report Share Posted September 10, 2004 If you can get the correct part, use it. Don't go cheap and use silicone. Quote Link to comment Share on other sites More sharing options...
rudefyet Posted September 10, 2004 Report Share Posted September 10, 2004 I just used silicone why? when you can fix it correctly for $3 if that. I seriously doubt I had 3 dollars at the time Quote Link to comment Share on other sites More sharing options...
Guest TurboSedan Posted September 10, 2004 Report Share Posted September 10, 2004 If you can get the correct part, use it. Don't go cheap and use silicone. silicone only sounds like a hack job to me. do it the right way. Quote Link to comment Share on other sites More sharing options...
WhiteOut Posted September 10, 2004 Report Share Posted September 10, 2004 How is high temp silicone a hack job? The stuff is indestructable and will never leak and it looks fine if aplied with some care? So why not use it if you've got it laying around as most of us do? Quote Link to comment Share on other sites More sharing options...
Guest TurboSedan Posted September 12, 2004 Report Share Posted September 12, 2004 because the gasket is really cheap anyway, and it is simply the right way to do it. if you feel comfortable using just silicone be my guest btw, i like your sig, my Lebaron would embarass you hardcore didn't mean to hurt your feelings calling your gasket 'fix' a hack job lol. Quote Link to comment Share on other sites More sharing options...
GutlessSupreme Posted September 12, 2004 Report Share Posted September 12, 2004 the gasket's called coolant bypass hose gasket, or something to that effect. I just replaced mine 3 weeks ago. I'll take a quick look in the manual tomorrow. Quote Link to comment Share on other sites More sharing options...
THe_DeTAiL3R Posted September 12, 2004 Report Share Posted September 12, 2004 Is it this?? http://www.napaonline.com/cgi-bin/ncommerce3/ExecMacro/NAPAonline/search_results_product_detail.d2w/report?prrfnbr=15587842&prmenbr=5806&usrcommgrpid=85410589 NAPA Gaskets Water By-Pass Gasket ($1.99) (NAPA item # NGAC31326) same part # for 1990 3.1 as well as a 95 3100.. or NAPA Gaskets Water Outlet Gasket (?) Item#: NGAC30820 Quote Link to comment Share on other sites More sharing options...
midnight rider Posted September 12, 2004 Report Share Posted September 12, 2004 How is high temp silicone a hack job? The stuff is indestructable and will never leak and it looks fine if aplied with some care? So why not use it if you've got it laying around as most of us do? BULLSHIT!!!!! I have had that stuff blow out on me so many times it isn't funny. I used to think that way too. I used to useit on thermostat housings and water pumps untill i noticed that after 6 months or so, i'd start seeing a leak. Use the correct gasket. They make and sell them for a reason. Quote Link to comment Share on other sites More sharing options...
GutlessSupreme Posted September 12, 2004 Report Share Posted September 12, 2004 Is it this?? http://www.napaonline.com/cgi-bin/ncommerce3/ExecMacro/NAPAonline/search_results_product_detail.d2w/report?prrfnbr=15587842&prmenbr=5806&usrcommgrpid=85410589 NAPA Gaskets Water By-Pass Gasket ($1.99) (NAPA item # NGAC31326) same part # for 1990 3.1 as well as a 95 3100.. that's it. my reciept shows that part number. Quote Link to comment Share on other sites More sharing options...
WhiteOut Posted September 12, 2004 Report Share Posted September 12, 2004 btw, i like your sig, my Lebaron would embarass you hardcore Perhaps in straight line acceleration you'd kick my ass, but I believe as soon as we hit corners you'd eat those words. Lebarons have the structural rigidity of chocolate pudding and the handling to match. Quote Link to comment Share on other sites More sharing options...
Guest TurboSedan Posted September 12, 2004 Report Share Posted September 12, 2004 i'm not going to go off topic just so i can prove how wrong you are Quote Link to comment Share on other sites More sharing options...
sl3196 Posted September 12, 2004 Report Share Posted September 12, 2004 i'm not going to go off topic just so i can prove how wrong you are Make a new post in whatever josh! Quote Link to comment Share on other sites More sharing options...
no1kicker Posted September 13, 2004 Author Report Share Posted September 13, 2004 Thanks for the help guys. I'd rather have a gasket there along with some sealer. Quote Link to comment Share on other sites More sharing options...
