Beretta Posted September 9, 2004 Report Posted September 9, 2004 how much is too much for stock turbo ? and engine ? i dont really plan to turn it up too much but im just curious. ::topic switch:: what about porting the tgp heads ? how should i do it is gasket matching enough ? Todd Quote
TurboGTU Posted September 9, 2004 Report Posted September 9, 2004 The TGP as how thise guys are turning it up...like about 10-12psi max. After that...its too much hot air. On porting.. On the heads..if your a novince or don't know jack about porting heads.. A good gasket match to the intake is good. Exhaust is a little tricky cause theres alot of free play with the gasket/manafold and head. What I would do if I were you is smoth the exhust manafold ports. Email me if you want to know where to port if you have the ability and tools to port good. This can be verry costly if you slip up and score the head deck. Quote
