Phat Pat Posted September 8, 2004 Report Posted September 8, 2004 yesterday I was sitting at a stoplight and my grand prix (1990) died, never done that before, I pulled into a parking lot (where I was going) and the temp was super high. later pulled out and heard the thermostat click on, temp dropped to normal. looked at it today after replacing the thermostat, and the rpms go up and down a few times until it just dies. anyone have any ideas? Quote
DaveFromColorado Posted September 8, 2004 Report Posted September 8, 2004 sounds like ya popped a headgasket. --Dave Quote
Phat Pat Posted September 8, 2004 Author Report Posted September 8, 2004 wouldnt it be leaking oil, or coolant like crazy then? Quote
94CutlassSLCoupe Posted September 8, 2004 Report Posted September 8, 2004 check the dipstick for the oil being milky or the level being too high Quote
DaveFromColorado Posted September 8, 2004 Report Posted September 8, 2004 unless it's tossing coolant into one of the cylinders, you can have an internal head gasket leak and not know it. --Dave. Quote
skiiirt Posted September 8, 2004 Report Posted September 8, 2004 :withstupid: Been there done that.. Quote
Phat Pat Posted September 8, 2004 Author Report Posted September 8, 2004 oil looks fine at the dipstick. I should note that it only does this up and down RPMs and die after idleing for 5 minutes or so, then stops when it warms up. If it's the head gasket its going to have to go to the junk yard, I've already put into it more than its worth. Plus im going to college in a year and wont have a need for a car. the only thing that would make it worth keeping is an engine swap, and I have no time, money, or workspace for that, not to mention I doubt I could handle the wiring tasks. if it is I will just drive my sister's tempo for the rest of the year. Quote
DaveFromColorado Posted September 9, 2004 Report Posted September 9, 2004 if it's a head gasket, and you're gonna junk the car, lemme know how much the yard will give ya for it, because I may be interested in an other 3.1 car, as I've got an extra 3100 sittin' in my garage right now. --Dave. Quote
THe_DeTAiL3R Posted September 9, 2004 Report Posted September 9, 2004 Sounds like you might need a tuneup. My 1988 ran like garbage then I cleaned the IAC/Throttlebody (really dirty), changed the t-stat, flushed the rad, and it ran MUCH better after that. I don't know why everyone it pointing at headgasket right away Quote
DaveFromColorado Posted September 9, 2004 Report Posted September 9, 2004 it overheated really baddly, and now it runs like crap at startup. checking the head gaskets would be the first thing I'd do. --Dave. Quote
94CutlassSLCoupe Posted September 9, 2004 Report Posted September 9, 2004 i guess it could also be the intake gasket...which is a lot cheaper Quote
Phat Pat Posted September 9, 2004 Author Report Posted September 9, 2004 it overheated really baddly, and now it runs like crap at startup. checking the head gaskets would be the first thing I'd do. --Dave. it didnt overheat really badly, just more than it should have been, not near the red. Quote
White93z34 Posted September 9, 2004 Report Posted September 9, 2004 ha thats the norm on these cars! mine will go almost to the red then the thermostat will open and the fans will kick on and bring it back down. i'd say your in need of a tuneup. Quote
94CutlassSLCoupe Posted September 9, 2004 Report Posted September 9, 2004 my car gets almost near the last white line (its a cutlass with the 92-94 analog cluster) before the t-stat opens. If it doesn't start spewing smoke from under the hood you are just fine. Quote
DaveFromColorado Posted September 10, 2004 Report Posted September 10, 2004 yeah, that's what they normally do. I figured if you were talkin' about how it heated up, and you pulled over that it had gone beyond it's normal point. That's all. now if it had overheated that baddly, then yes, you probably would need a head-gasket, but for now, I'd say tune it all up. --Dave Quote
Regal_GS_1989 Posted September 21, 2004 Report Posted September 21, 2004 If you overheated it really bad, you probably cracked the head(s) I have an 89 regal that overheated in traffic, and cracked both the heads in the little space between the two valves. They're not that hard to fix yourself if you've got a garage, and patience. It cost me 350$ to replace the heads and head gaskets on my 3.1. Quote
