Any reason gauges for 99-00 Lumina won't work on 96 Lumina??
Does your car have a column shift or floor shift? Check out ProCarParts, they have several different overlays for the Luminas.
http://www.procarparts.com/store-list.asp?categoryID=3&subcategoryID=37&maker=CHEVROLET&model=LUMINA
I think the only differences between the 95-98 and 99-00 Lumina clusters were on the column-shifted ones. The older ones had the phrase "APPLY BRAKE TO SHIFT FROM PARK" directly above the gear indicator, the newer ones had the phrase on the right-hand "pod" (below the temp gauge on the non-tach clusters...) All of the idiot lights and such should line up perfectly...
I say go for it!
No difference except for the "Apply Brake.." location as Disco said.. Nothin wrong with that action.. Go for them.. If you dont have the gauge package in you Gen 1.5 Lumina, here's a tip: Look for Monte Carlos between 95-99 for them.. Its more likely they had them.. :P
