uh oh! pulleys..i think
went to start the car yesterday and smoke started rolling off the power steering pump pulley, so i filled it up with some fluid and that stopped but there was a kind of whining sound and it wasnt the belt squeaking more like a pulley bearing went out or something and then my altenator had a little bit of smoke coming of it like it was being overworked...does anyone know what this might be
Guest Anonymous
Your power steering pump (bearing) is probably shot, causing the whining.
It may have thrown some power steering fluid into the alternator causing it to smoke as it burns off.
Do you know what would have to be replaced on it, like the entire pump or what? thank you
Guest Anonymous
I would just replace the pump. You'll probably have to put your resorvoir on the new pump. There are two clips that hold them together. I priced a rebuild kit for my pump once and it was only $2 cheaper than buying a new pump.
