Guest RedCutlassSL Posted December 24, 2002 Report Posted December 24, 2002 I noticed my brakes make a grinding sound when i'm applying them. Otherwise the pedal feels fine and the car stops fine. I've got new pads on the front, and one side on the rear has new pads and a rotor. Any ideas? Thanks Quote
taylerade Posted December 24, 2002 Report Posted December 24, 2002 yea had the same problem. applied Permatex® Disc Brake Quiet all around where the pads were held. problem vanished. can get that sealant at any parts store for 7 bucks or les. pulled off a webpage (Stops brake squeal by dampening vibration at caliper/brake pad interface. Provides tighter fit and allows for easier disassembly. Protects against corrosion. Compatible with anti-lock brake systems. Aerosol - Level 3) Quote
