reverse gear doesn't work with gas pressed
well here is whats going on my daily driver its reverse gear has started to making noise when i try to use reverse. i checked the fluid its black so tomorrow after school i'm going to park it get the tranny fluid swaped out and the filter. hopefully that will fix my car any thing else i should check?
FYI the car is a 1988 cutlass supreme with a 440t4 tranny.
Cut the filter up........see whats inside of it. Lots of grey chunky bits indicate smoked clutches/bands. Metal is just bad all together.
Apparently the reverse band isn't functioning right.......the band maybe smoked, the solenoid could be fucked, or might not be getting hydrallic fluid to actually function.
