92blackz34 Posted September 1, 2004 Report Share Posted September 1, 2004 hello. i was wondering how hard is it to install a dic into a 92 lumina z34? or is there anyone in northern mn that would be willing to help me put one in thanks. Quote Link to comment Share on other sites More sharing options...
midnight rider Posted September 1, 2004 Report Share Posted September 1, 2004 SEARCH is there for a reason. Use it. This topic has been brought up more times than a hard on at a porn convention. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 1, 2004 Report Share Posted September 1, 2004 i think steveasphsycho has done it and a few others. its not plug and play. Quote Link to comment Share on other sites More sharing options...
supreme_style21 Posted September 1, 2004 Report Share Posted September 1, 2004 Where in MN? Quote Link to comment Share on other sites More sharing options...
92blackz34 Posted September 1, 2004 Author Report Share Posted September 1, 2004 buhl if you know where that is. its 10 minutes away from hibbing Quote Link to comment Share on other sites More sharing options...
supreme_style21 Posted September 1, 2004 Report Share Posted September 1, 2004 Sure do.. WAY too far from here. Quote Link to comment Share on other sites More sharing options...
White93z34 Posted September 1, 2004 Report Share Posted September 1, 2004 steve has yet to atempt this but he will, ask badfish he successfuly did it. Quote Link to comment Share on other sites More sharing options...
GOT2B GM Posted September 1, 2004 Report Share Posted September 1, 2004 Hi, I put one in my 93 Z34. I used the entire DIC console out of a GP. You have to remove the Lumina ashtray from the bottom of the dash in order for it to fit, but thats ok because there's an ashtray in the new console. Just extend the wires for the lighter. You'll have to run your own wires as the Lumina's are not prewired for it. COLOR - - PIN # - - DESCRIPTION - - LOCATION Orange - - A1 - - 12V Constant - - Fuse box Pink/Black - - A2 - - 12V Ignition - - Under steering column-pink Dk. Green - - A6 - - VSS Signal - - Cluster-Dk. Green-pin D5 Orange - - A7 - - ALDL Signal - - ALDL connector-orange Black - - A8 - - Ground - - Ground Gray - - B3 - - Dimmer - - Ashtray/gear selector light Purple - - B6 - - Fuel Level Signal - - Cluster-Purple-pin C5 Black - - B8 - - Ground - - Ground This will get your DIC fully functional, minus the door/trunk/hood triggers if you have the STE DIC. Hope this helps Quote Link to comment Share on other sites More sharing options...
Baddflash Posted September 3, 2004 Report Share Posted September 3, 2004 steve has yet to atempt this but he will, ask badfish he successfuly did it. It's baddflash :? Anyway it's not bad to put in , just follow 93Luminaz34 instructions and you shouldn't have any problems. But if you need help let me know. Edit: I left my ashtray in place and it's isn't in the way at all! Quote Link to comment Share on other sites More sharing options...
DiscoStudd Posted September 3, 2004 Report Share Posted September 3, 2004 buhl if you know where that is. its 10 minutes away from hibbingAah, up on the "Iron Range." I lived in Hibbing for about 2 years when I was real young (right next to Ranger Chev if that's even still there...) Quote Link to comment Share on other sites More sharing options...
digitaloutsider Posted September 3, 2004 Report Share Posted September 3, 2004 I think he was thinking about the GP when he said remove the ashtray.. Quote Link to comment Share on other sites More sharing options...
Baddflash Posted September 3, 2004 Report Share Posted September 3, 2004 I think he was thinking about the GP when he said remove the ashtray.. :shock: You have to remove the Lumina ashtray from the bottom of the dash in order for it to fit, but thats ok because there's an ashtray in the new console I'm pretty sure he meant the Lumina. Quote Link to comment Share on other sites More sharing options...
z34_nut Posted September 3, 2004 Report Share Posted September 3, 2004 too bad they don't make them in red, or else i would have already done it. Quote Link to comment Share on other sites More sharing options...
GOT2B GM Posted September 7, 2004 Report Share Posted September 7, 2004 Yeah I was talking about the Lumina ashtray. I didn't know the console would fit with it in. Quote Link to comment Share on other sites More sharing options...
