93CutlassSupreme Posted September 1, 2004 Report Share Posted September 1, 2004 tighten this bolt. my door clicked every time i moved it, now it doesn't after i tightened this. it was loose i tighened it until i couldn't move the ratchet anymore without really straining at it. i'd get it tight but i wouldn't strip the bolt or anything. Quote Link to comment Share on other sites More sharing options...
GPdriver1986 Posted September 2, 2004 Report Share Posted September 2, 2004 I checked that bolt its tight, I'll tighten the other ones maybe tommorow, if it doesn't hurt. Is there supposed to be play on the joint in the middle? Quote Link to comment Share on other sites More sharing options...
93CutlassSupreme Posted September 2, 2004 Report Share Posted September 2, 2004 I checked that bolt its tight, I'll tighten the other ones maybe tommorow, if it doesn't hurt. Is there supposed to be play on the joint in the middle? i wouldn't think so. i have some, but not a lot if there is, that's probably your problem Quote Link to comment Share on other sites More sharing options...
SigEpCutlass Posted September 2, 2004 Report Share Posted September 2, 2004 i know for a fact when mine clicks i can see it almost "slipping" in the middle. It doesn't do it all the time either...it almost seems weather related on my cutty's driver door. Quote Link to comment Share on other sites More sharing options...
Bruticus Posted September 2, 2004 Report Share Posted September 2, 2004 Why not just lube the hinges and door holder-opener with wd40? That's always fixed any noise issues with my Cutlass. Maybe I'm pointing out the obvious, but sounds like you haven't tried it yet. Agreed get some WD 40 in there i had the same problem when i first bought my Lumina. I dont hear anything at all now and its been 2 and a half years. Quote Link to comment Share on other sites More sharing options...
SigEpCutlass Posted September 2, 2004 Report Share Posted September 2, 2004 Why not just lube the hinges and door holder-opener with wd40? That's always fixed any noise issues with my Cutlass. Maybe I'm pointing out the obvious, but sounds like you haven't tried it yet. Agreed get some WD 40 in there i had the same problem when i first bought my Lumina. I dont hear anything at all now and its been 2 and a half years. i've put wd40 on that joint in the middle countless times and it hasn't done anything. Quote Link to comment Share on other sites More sharing options...
THe_DeTAiL3R Posted September 2, 2004 Report Share Posted September 2, 2004 I also have put WD-40, and balljoint grease on it but it does nothing. If you have squeeky hinges it will work for that, but I think the part is simply worn out. Quote Link to comment Share on other sites More sharing options...
Brian P Posted September 2, 2004 Report Share Posted September 2, 2004 I'm not sure if it was mentioned (Im not checking 3 pages) but your check hinge is probably loose. Remove the little rubber cap and there's 2 bolts I believe 13mm maybe 10mm depending on year. Tighten em up. Quote Link to comment Share on other sites More sharing options...
GPdriver1986 Posted September 2, 2004 Report Share Posted September 2, 2004 know for a fact when mine clicks i can see it almost "slipping" in the middle. It doesn't do it all the time either...it almost seems weather related on my cutty's driver door. Same thing that mines doing, i'm gonna try to tighten those 5/16'' bolts at the door and see if it helps more., then i'll spray it with WD40. Quote Link to comment Share on other sites More sharing options...
whiteSE Posted September 6, 2004 Report Share Posted September 6, 2004 Both of the ones on my GP are broken off - doors will not stay open at all!! I figure I have lived with it like that since I have had my GP so what's another couple of years!! Good to know that they are easily replaced. May have to go to the junkyard and grab some "new" ones. Phil Quote Link to comment Share on other sites More sharing options...
jeremy Posted September 7, 2004 Report Share Posted September 7, 2004 Good to know that they are easily replaced. May have to go to the junkyard and grab some "new" ones. Phil your knees with thank you... Quote Link to comment Share on other sites More sharing options...
