Manual trans gurus need lots of info
ok i am doing a manual swap in my 96 grand prix with a L67. I am using parts from a 92 chevy lumina with a get rag 284 trans. First question.....I need a clutch that is strong enough to hold 300+ HP. I am using a modded camaro flywheel + the kit.
second question......if i end up fogetting about the 284 and go with the 282 getrag trans what would need to be change in order to switch over...i know clutch kit....i need to know about linkage and clutch master cylinder.
anyone who has any info let me please
Shift cables are the same, Clutch and all the hydraulics are completely different.
what part of the hydrolics are different...is it something easy to swap if i were to change transmissions
i know that i need to know the parts involved that need to be changed. i am going to start with the 284 because i have it and when it blow up or i have enough money i am going to change it
Would the 282 be able to hold up to the L67's torque at a HP figure of 300+ HP for long? Cause I was thinking of doing the L67 with a manual tranny, the Getrag 282, but I've heard bad things about the 282 and that it can't withstand the torque from an L67.
I highly doubt it.. Use a 284.
actually all the fiero guys use is the getrag 282. they bolt the trans up to every motor they use. the getrag 284 is the worst trans to use because of the inability to rebuild it. the only reason i am using it right now is because the parts car i have has the 284 in it
A fiero doesn't way near as much as your car does. Chances are it won't hold up to the weight of a W-body plus the torque of the L67.
that is up to you. right now i am doing a 284 swap with mine and there is a guy with a 282 doing a L67 swap. so you will know soon enough. for now to get the motor in and all the kniks out do the auto trans then switch it over
