throttle position sensor?
I got a 89 grand prix 2.8l put a new TPS on it and the book says with the throttle closed put on TPS and rotate counterclockwise and i did that and the eng idles at 2.000 RPMs do i need to ajust it to lower the idle if so what way and how?
Were you having idle problem before you swapped the TPS?
Can you rev the engine? If so the TPS should be on right and you may have problems else where causing high idle. The idle is not adjustable the computer contols that electronically using input from various sensors.
ya i've had idle problem for a long time and i put alot of stuff new on it and it still idle funny and some times when i turn the car off it wont start and when i mash the throttle all the way the eng dies but the tech is still in the same place never moves and it comes back to life here is what i put on new
ICM
CRANKSHAFT POSITION SENSOR
OXYGEN SENSOR
THROTTLE POSITION SENSOR
FUEL PRESSURE REGULATOR
MAP
PCV VALVE
FUEL PUMP
SPARK PLUG
WIRES
thats it
You've cleaned the throttle body I assume? Maybe the injectors are dirty or maybe one or more are faulty. How about replacing the fuel and air filter. It could be the coils to I suppose???
