Black5spdZ Posted August 28, 2004 Report Posted August 28, 2004 I AM TRYING TO FIX MY SPEEDO AND JUST WONDERED HOW TO GET THE NEEDLE OFF ANY HELP IS APPRECIATED Quote
EurosportZ34 Posted August 28, 2004 Report Posted August 28, 2004 Hrmm...I don't really get the problem your having, please explain. Quote
THe_DeTAiL3R Posted August 28, 2004 Report Posted August 28, 2004 When you have access to the needle I think you just pull it off Quote
Black5spdZ Posted August 29, 2004 Author Report Posted August 29, 2004 MY CAR HAS WHITE FACED GAUGES AND THE GUY SAID WHEN THEY WERE INSTALLED THE SPEEDO QUIT WORKING, MY ODOMETER STILL WORKS. i PUT THE CLUSTER OUT OF MY OTHER Z34 IN AND THE SPEEDO WORKED FINE SO IT HAS TO MY CLUSTER OR THE LITLLE MOTOR BEHIND IT ANY SUGGESTIONS? Quote
digitaloutsider Posted August 29, 2004 Report Posted August 29, 2004 http://maddox.xmission.com/hatemail.cgi?p=1#CAPSLOCK Anyhow, the idiot most likely fucked up the cluster. Quote
GP1138 Posted August 29, 2004 Report Posted August 29, 2004 MY CAR HAS WHITE FACED GAUGES AND THE GUY SAID WHEN THEY WERE INSTALLED THE SPEEDO QUIT WORKING, MY ODOMETER STILL WORKS. i PUT THE CLUSTER OUT OF MY OTHER Z34 IN AND THE SPEEDO WORKED FINE SO IT HAS TO MY CLUSTER OR THE LITLLE MOTOR BEHIND IT ANY SUGGESTIONS? OMG OMG OMG USE COMMAS AND TURN OFF YOUR CAPS LOCK OMG LOLOL!!!!!111 Quote
jeremy Posted August 31, 2004 Report Posted August 31, 2004 the easiest method that I found was to take to spoons from the kitchen drawer and use put the edge of each spoon on the underside of the needle and apply equal pressure to each spoon, this should pry the needle off with very very little chance of breaking it.... Quote
GP1138 Posted August 31, 2004 Report Posted August 31, 2004 spoons?why spoons? Because you can use the convex part of the spoon as a lever, rather than pulling up on knives. Anyway, he's just telling you what worked for him. Quote
digitaloutsider Posted August 31, 2004 Report Posted August 31, 2004 spoons?why spoons? Because he's racist against forks. Quote
midnight rider Posted August 31, 2004 Report Posted August 31, 2004 spoons?why spoons? Becuase it will hurt more, you TWIT!!!! Sorry, was thinking of that Robin Hood movie....lol Quote
