skiiirt Posted August 28, 2004 Report Posted August 28, 2004 Well I finally came across an other problem.. It's been a long time since I've had the car under the microscope (almost a week) I have been getting a SES 32. So I went and switched out the EGR valve with a brand new AC Delco EGR Valve. The car still seems to be having troubles just no SES light this time. (thats a lie, about 20 mins after the car is at normal operating temp the light will come on, then wont come back after I shut the car off) Could this be caused by the gaskets that the EGR sits on? Should I replace those? I just replaced the big black valve, no gaskets or anything What else should I be doing? After installing something like this should I reset my ECM or something? The car symptoms are rough idle/run and the rpms surge from 200 - 1000rpms when driving at slower speeds and stopped Any ideas guys? Quote
maybe2fast Posted August 29, 2004 Report Posted August 29, 2004 u should have replaced the gaskets and try unhooking the battery that will clear the codes out of memory and start from new. try that and get back to us -Don Quote
skiiirt Posted August 29, 2004 Author Report Posted August 29, 2004 ok, cleared the ECM, did the idle relearn. Unfortunately I think I busted one of the gaskets putting it in. I'm waiting for monday so I can go order another one. The car seems to have been running better except I have come across an unusual amount of stalling. From not stalling once in 5000km to stalling once a day. I have a feeling the EGR valve isn't at fault. I did get another code 32 SES light. Anything else I should be replacing? Quote
WhiteOut Posted August 30, 2004 Report Posted August 30, 2004 Try cleaning out the EGR passages on the intake as well. Get new EGR gaskets, it will only run about $4. Quote
skiiirt Posted August 30, 2004 Author Report Posted August 30, 2004 like the port that the actual valve sits on? With what would you clan it with? I was scraping gasket off the bottom of my egr valve before i put it back on, but that was as far is i took it Off to find a dealership with that gasket oh btw it's a $1.50 gasket Quote
slick Posted August 30, 2004 Report Posted August 30, 2004 Take off the egr and spray some carb cleaner into the little ports. Then, take a coat hanger or something and go at it. Should help. Quote
Manny Posted August 30, 2004 Report Posted August 30, 2004 ...they were discussing the very same issue on 60degreev6.com, and came up with some interesting conclusions-especially the bottom of page 1 and some of page 2 http://www.60degreev6.com/forum/viewtopic.php?t=3030 Quote
skiiirt Posted August 31, 2004 Author Report Posted August 31, 2004 Thanks for the read. I do believe I have done almost everything said on that message board. The fuel injectors were done long ago I am thinking of just disabling the freakin thing. But I have heard that it still gives out the SES light? True or False? I dont particularily want to remove my computer chip, not only is it a brand new one but I dont even know where to begin lookin that and I'm tapped for $ Anyways. I replaced the gaskets, cleaned it to the best of my ability (without a spray) and the car was running AWESOME but about 50km later I got a SES light. I havent scanned but im more than 100% sure it'll report 32 Quote
