Puggsley456 Posted August 28, 2004 Report Share Posted August 28, 2004 I need help guys! I think the car audio shop installed the wireing for my rear 6x9's backwards! Can someone tell me, on the factory wireing which wire(color) was possitive and which is negative so I can look and if its wrong take it back. Quote Link to comment Share on other sites More sharing options...
midnight rider Posted August 28, 2004 Report Share Posted August 28, 2004 Gm uses a pretty standerd wiring setup for audio. Both my Chiltons and my Haynes show this: Rear D-side Dark Brown = POS Yellow = NEG P-side Dark Blue = POS Light Blue = NEG Front D-side Tan = POS Gray = NEG P- side Dark Green = NEG Light Green = POS Black = GROUND Orange = 12 V POS BAT Yellow = 12 V POS SWITCH I hope this helps...... Quote Link to comment Share on other sites More sharing options...
MIKELABZ Posted August 28, 2004 Report Share Posted August 28, 2004 this needs to be a sticky. Quote Link to comment Share on other sites More sharing options...
midnight rider Posted August 28, 2004 Report Share Posted August 28, 2004 The sad thing is I did that from memory then looked it up in my chiltons and haynes to make sure it was right before posting it. Quote Link to comment Share on other sites More sharing options...
DiscoStudd Posted August 28, 2004 Report Share Posted August 28, 2004 The sad thing is I did that from memory then looked it up in my chiltons and haynes to make sure it was right before posting it.Every diehard GM guy should be able to rattle those wire colors off on a whim like that! I usually get the left front colors mixed up, but the rest are easy because the dark colors are the positives... Quote Link to comment Share on other sites More sharing options...
