dohc v6 Posted August 27, 2004 Report Share Posted August 27, 2004 i replaced my battery the other day and now my cruise control does not work. i checked the fuse in the car and it was ok. could it be any thing else. Quote Link to comment Share on other sites More sharing options...
Dirty Rockstar Posted August 27, 2004 Report Share Posted August 27, 2004 Check the cruise module thing in the engine bay.. I forgot the name.. But the vacuum thing that holds the trottle.. Itss black and makes a springy sound when you bump it.. Ive undon something replacing a battery before.. Good luck! Quote Link to comment Share on other sites More sharing options...
DOHCRagtopguy Posted August 27, 2004 Report Share Posted August 27, 2004 Check your vacuum lines. They run right around that area, perhaps you cracked one inadvertently or popped one off. Just trace them from the slave cylinder to the ball under the battery. Good luck! Quote Link to comment Share on other sites More sharing options...
digitaloutsider Posted August 27, 2004 Report Share Posted August 27, 2004 Ensure the vacuum check valve is in good condition and not cracked/broken. Quote Link to comment Share on other sites More sharing options...
midnight rider Posted August 27, 2004 Report Share Posted August 27, 2004 Check to see if the wire is still pluged into it. I knocked one loose on something putting a batery in. Quote Link to comment Share on other sites More sharing options...
