stilesr9167 Posted August 25, 2004 Report Posted August 25, 2004 I have a 92 lumina z (and a 99 dodge ram 2500 sport) For the rare ocasion that my z is not in the shop I would love to spend some more time. On small little modifications, I have the mufflers tips and high flow converter on order, I have AR 17" crhome rims that I like but unless I find a retailer that stocks stuff for my car I am very limited.. Bottom line ___________ does anyone have a good resorce for goodies for the z? Quote
slick Posted August 25, 2004 Report Posted August 25, 2004 Good resources, no. Your pretty much on your own when it comes down to a lot of things. Fast Forward Performance does sell a computer chip, a better dogbone mount, and an underdrive pulley among things that will help out your car. As for exhaust, Borla makes a nice, and quite expensive exhaust system. Your best bet for that is to have a local shop do you up an exhaust system (2.5" mandrel bent tubing). Other then the things listed, your pretty much on your own on anything else. Quote
Crimson Fury Z Posted August 26, 2004 Report Posted August 26, 2004 theres the 13 degree exhaust cams retard, if you have or have access to thew cam hold down tools. look for a used K&N filter, run royal purple. if you get 17"s, go get corvette sized rotors and brakes! Quote
jeremy Posted August 26, 2004 Report Posted August 26, 2004 if you stock exhaust isn't trashed, I would be interested in getting it from you once you get your new one.... Quote
