LarryMartin830 Posted August 25, 2004 Report Posted August 25, 2004 well i/moms car didn't come with it dose any one have all the stuff to have it on my car? i got money to burn not much tho lol Quote
Guest TurboSedan Posted August 25, 2004 Report Posted August 25, 2004 are you sure it didn't come with it? it seems like most of them did, even my base Cutlass sedan did. i had no idea it had keyless entry until i looked at the Service Parts Identification sticker in the trunk - look for RPO option code 'AUO'. if it doesn't have the keyless entry option, it would probably be quite a job wiring all of it in. Quote
LarryMartin830 Posted August 25, 2004 Author Report Posted August 25, 2004 is that the little sticker? because the other one is about tires Quote
THe_DeTAiL3R Posted August 25, 2004 Report Posted August 25, 2004 There is a single wire by the antenna (take the carpet off) the wire would just be dangling there. If you push the connector against a ground (like the screw) the doors will lock and unlock... which means you have keyless entry. Grounding the connector and pressing a button on the remote(s) programs the remote(s). Remotes also known as FOBs... someone please tell me what FOB stands for! Quote
LarryMartin830 Posted August 25, 2004 Author Report Posted August 25, 2004 well i don't got it thanks for the help Quote
Guest TurboSedan Posted August 25, 2004 Report Posted August 25, 2004 is that the little sticker? because the other one is about tires it's the sticker in the trunk, about 4" x 6" or so. it should be on the spare tire cover. it says "Service Parts Identification" on the top and has a bunch of alpha-numeric 3-digit codes on it. the VIN will be on it, as well as the paint codes. Quote
GutlessSupreme Posted August 25, 2004 Report Posted August 25, 2004 There is a single wire by the antenna (take the carpet off) the wire would just be dangling there. If you push the connector against a ground (like the screw) the doors will lock and unlock... which means you have keyless entry. Grounding the connector and pressing a button on the remote(s) programs the remote(s). Remotes also known as FOBs... someone please tell me what FOB stands for! Fucking Obsolete Batteries. lol I dunno. I do hate those batteries though. Quote
DiscoStudd Posted August 25, 2004 Report Posted August 25, 2004 Here ya go, everything you need to know about the SPID, courtesy of the main W-Body dot com site: http://www.w-body.com/rpo.html Quote
LarryMartin830 Posted August 25, 2004 Author Report Posted August 25, 2004 Here ya go, everything you need to know about the SPID, courtesy of the main W-Body dot com site: http://www.w-body.com/rpo.html thank u Quote
