Window seal problems
whenever i roll down either of my front two side windows, the inside seal at the bottom of the window gets pulled down with the glass into the door
any ideas on why it does this? it only started a couple weeks ago, and i finally decided to ask about it
Does the window roll down smoothly? (maybe the tracking needs adjustment?)
Otherwise my guess is the seal has an issue..
Is it just the seal that usually points upwards? If so, I really woulnd't worry about it. IT may just be that it's getting old and more flexible than what it used to be.
I understand what you are saying but it just doesn't make sence to me.. the seals on my 88' are old and hard. :confused:
I believe that's called the "Belt Weatherstripping" for those wondering. And, yes the outers are a pain in the ass to remove (at least they were on my old 85 Grand Am.) I can't seem to remember if the inners were attached to the door panel in my Regal or not :think:
I believe that's normal for the belt weatherstripping to flex like that. I've seen many cars do that (I remember my 94 Grand Am doing that when it was brand new.) I'd say if it isn't hindering the raising and lowering of your window, then it should be fine...
