Crimson Fury Z Posted August 25, 2004 Report Posted August 25, 2004 ok, the switch that came w/ them is as follows; 6A 125VAC 3A 350VAC its a 2 prong switch the one i'd like to use is this; 10A 125VAC 6A 250VAC this is one of the like 1" round led switches, 3 prongs i can get the led to light, but the neons wont. does the A & VAC #'s from the old one need to match any new switch? thanks in advanced Quote
THe_DeTAiL3R Posted August 25, 2004 Report Posted August 25, 2004 you probably have the switch hooked up wrong might need to cross 2 of the prongs since there is an extra one.. I dunno *Note: I claim no responsibility for any advice given on w-body.com* Quote
runt Posted August 25, 2004 Report Posted August 25, 2004 How do you have your wiring run? By that I mean if you are running a 3-pronger it should be like this: 1 - HOT 2 - Going to your lights 3 - Ground. Basically prong 1 and 3 are getting run from the car to the switch, the 2nd one is going from the switch to your lights. Does that make sense? Thats how I have mine. Quote
loominaz34 Posted August 25, 2004 Report Posted August 25, 2004 The positive and the one for the light in the switch (usually in the middle) get positive. The negative is grounded. Quote
