supreme_style21 Posted August 23, 2004 Report Share Posted August 23, 2004 I cannot see an immediate physical difference between the two. Are the connectors the same? Quote Link to comment Share on other sites More sharing options...
GP1138 Posted August 23, 2004 Report Share Posted August 23, 2004 I cannot see an immediate physical difference between the two. Are the connectors the same? Let me guess, top is '97+ and bottom is 94-96. The oil and temp. gauges are switched, first of all. Don't know about the connectors. Quote Link to comment Share on other sites More sharing options...
Bruticus Posted August 23, 2004 Report Share Posted August 23, 2004 One goes to 7000 rpms the other goes to 8000 Quote Link to comment Share on other sites More sharing options...
supreme_style21 Posted August 23, 2004 Author Report Share Posted August 23, 2004 Yeah I can see that much.. I'm just wondering if they're swappable. Doubtful.. just curious. Quote Link to comment Share on other sites More sharing options...
DiscoStudd Posted August 23, 2004 Report Share Posted August 23, 2004 I think the whole dash on the 97-03's are larger than the 94-96's, therefore the cluster (im sure) is a tad bit bigger. If it even fit, then you could always modify your harness to plug up to the newer cluster. Pinouts will most likely be in different locations, but it should wire up fine... Quote Link to comment Share on other sites More sharing options...
jeremy Posted August 26, 2004 Report Share Posted August 26, 2004 I think the whole dash on the 97-03's are larger than the 94-96's, therefore the cluster (im sure) is a tad bit bigger. If it even fit, then you could always modify your harness to plug up to the newer cluster. Pinouts will most likely be in different locations, but it should wire up fine... but why would you go through all that work for a cluster that is so similar in appearance.... Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 26, 2004 Report Share Posted August 26, 2004 The oil and temp. gauges are switched, first of all. Oil gauge? All I see is fuel and temp. But yes, they are switched. Quote Link to comment Share on other sites More sharing options...
GP1138 Posted August 26, 2004 Report Share Posted August 26, 2004 The oil and temp. gauges are switched, first of all. Oil gauge? All I see is fuel and temp. But yes, they are switched. Well I'll be damned. LOL. My bad. Reminds me of why I don't want a 94+ Prix. I like seeing my oil pressure, and I don't like aftermarket gauges. Quote Link to comment Share on other sites More sharing options...
jeremy Posted August 26, 2004 Report Share Posted August 26, 2004 Reminds me of why I don't want a 94+ Prix. I like seeing my oil pressure, and I don't like aftermarket gauges. or almost any newer GM for that matter...... Quote Link to comment Share on other sites More sharing options...
GP1138 Posted August 26, 2004 Report Share Posted August 26, 2004 Reminds me of why I don't want a 94+ Prix. I like seeing my oil pressure, and I don't like aftermarket gauges. or almost any newer GM for that matter...... Quote Link to comment Share on other sites More sharing options...
DiscoStudd Posted August 26, 2004 Report Share Posted August 26, 2004 but why would you go through all that work for a cluster that is so similar in appearance....My guess is so he can have the LED gear indicator, which the 94-96's don't have... Quote Link to comment Share on other sites More sharing options...
supreme_style21 Posted August 26, 2004 Author Report Share Posted August 26, 2004 I'm just curious as to the differences.. not planning on changing anything really... might keep me occupied on a boring day. Quote Link to comment Share on other sites More sharing options...
