RareGMFan Posted August 23, 2004 Report Posted August 23, 2004 Does anyone know where the TPS and MAP sensor would ground to? Come to think of it, could someone point out where all the grounding points for the engine/computer/sensor wiring is? Quote
slick Posted August 23, 2004 Report Posted August 23, 2004 Ooooh ooh, i can help out a little on this one. The battery to body ground is right at the battery, same with the battery to block ground. Just follow the wires and you'll find them. I searched forever, and was finally told that the block to body ground flows through thoughs same wires. Now, as for the MAP and TPS grounds, can't help you there. Quote
Jcrow Posted August 23, 2004 Report Posted August 23, 2004 There is a sensor ground that goes to the computer Quote
