How to keep low beam on w/ highs?
How do you keep the low beams on with the high beams? Fog lights as well, if it isn't an extra hassle. I've seen 'kits' for cars but if I can do it with some relays and whatnot, cool.
Couldn't you just splice into the wires that go to the highbeams, and wire that up with the lowbeams/fog lights?
With my 'trial and error' schemes, I figured I'd give that a shot, but a buddy of mine said I'd need to tie relays in there somewhere.
Actually scrap my simple idea... the highbeams would be on with the lowbeams all the time. I hate electronics!
I'd use a relay. The way I'd probably do it is to go under the dash and find the high and low beam wires out of your turn-signal switch, then feed the low beam from one of your contant powers for your ign. switch, switched on by the high beam wire and a ground.
Now which pin would that be? I assume you're talking in the actual switch to turn 'em on/off, right?
on mine, it was the top left when looking at it from the drivers seat when its all intact... top right when you're actually looking at all the pins straight on. and yeah, the actual switch. the only thing with that is the fogs don't come on with the lows.
EDIT: Oh yeah, but that makes the buzzer not work that's supposed to warn you when you leave the lights on after shutting off the car. Hence the reason I ran my battery dead twice this week :D
Must be a different setup.. I just ran out to check.. there isn't anywhere for the pins to go.
That's weird, my Cutlass convertible had both the brights and dims on when you kicked the brights on. I just assumed that all the cars with the mini-quads were this way..
oops, I lied. Mine do have both lows and highs with the brights on, but not fogs with highs...
I need to pay more attention to things
:lol: The cars with the mini-quads have that setup.. anything else does not.. I fall into that category.
Shit.. I forgot you had the lightbar on your car! Derp de derp! :oops: :lol:
Yeah I've seen those kits and was gonna try avoid 'em, but when you add up the cost of relays and wire, the price comes out to be about the same.. so perhaps I'll end up going that route.
You'd have to do relays. All the power to the headlights runs through the light off/on switch and the dimmer switch also I think. If you managed to get all four on without relays wired in from the alternator, ...you'd get a pretty hot light switch.
