Power Steering Hose: O-Rings
I just replaced the pump, pressure and return lines (what an ordeal).
Now I can't get the pressure hose to stop leaking at the pump. The o-ring gets cut every time I try to tighten the fitting. I'm not over tightening the fitting. I even tried another pump with no success.
Yes, I oiled the o-rings before installation.
Any help, tips would be appreciated.
Is the line end malformed in some way? What about the pump fitting? I've tightened lines before on the PS pump and never had an o-ring cut.
Jason
