CAI & Battery movage
Someone once said that supposedly, the battery will bolt down/fit/whatever no problem to where the factory airbox on the 3.1 is, eliminating the need to move it to the trunk when installing a CAI piped out to the fender. Does anyone know if this is true?
someone on the board has a 3.1 with a CAI without moving the battery, but moving the battery isnt a hard job, run a 2-0 gauge wire from the terminal with the brake lines, stick a grommit in the trunk, put a battery box in there and run a ground 2 the body.
