stlunatics2oo3 Posted August 17, 2004 Report Posted August 17, 2004 okay i have an idle issue i do an idle relearn and the car runs good for a few starts and then on an odd number of starts it idles really high like 1000 rpms in drive and like 1500 in park i believe it is electrical problem i have changed : intake manifold gaskets i.a.c t.p.s i.a.t all vacuum lines around the engine fuel injectors coil packs and module spark plugs and wires 02 sensor cleaned the plenum and throttle body plus the egr ecm is good okay ppl. i believe that is all i have changed so i believe it is electrical so if you have an idea or something let me know thanks Jeremy Quote
White93z34 Posted August 17, 2004 Report Posted August 17, 2004 the basics, what year, model, engine? mabie an intermitent vaccum leak, or makbie uperintake gasket shot? Quote
stlunatics2oo3 Posted August 17, 2004 Author Report Posted August 17, 2004 89 cutlass automatic 2.8 and upper intake gaskets have been changed Quote
White93z34 Posted August 17, 2004 Report Posted August 17, 2004 i'd look over your vaccum lines real good Quote
