Where do these plugs go?
I found a couple plugs behind the engine on my car that aren't plugged in... Here are a couple pictures I've taken.
This one is located behind the intake plenum, it looks like an 02 sensor plug. It comes off the wiring harness right behind the plenum as well.
The second plug, here: conley-plug2.jpg is located near the metal hose that goes to the exhaust manifold on the rear of the engine. It goes to a sensor or something on the side of the block, but what plugs into it and what does it do?
I hope someone has the answers. Thanks in advance.
Guest Anonymous
The 1st one looks like the one for the coolant sensor in the corner of the rear head.
The 2nd one I'm not sure of.
I don't think 92 3.1s (sorry forgot to mention it's a 92 Lumina 3.1)
had the 7th injector, and also the injector plugs are sorta squarish. The first plug shown has the same kind of pigtail connector as the o2 sensor, though.
