Speckkial Posted August 16, 2004 Report Posted August 16, 2004 I have a 93 Cutlass Supreme 3.1L and when I bought the car I was told that the AC needed to be re-charged. Well....It's been about two months since then and I haven't got the AC re-charged but I did try to turn it on one day while going through a car wash. It blew out these smelly ass fumes and I almost let all the windows down in the car wash. My question is, will not re-charging my AC affect the heat also? I'm not trully concerned about having AC during the summer but I am concerned about having heat for the winter. Quote
digitaloutsider Posted August 16, 2004 Report Posted August 16, 2004 I don't even have my compressor on the belt any longer. Your A/C system has nothing to do with your heater. Quote
Speckkial Posted August 17, 2004 Author Report Posted August 17, 2004 I thought so but I wasn't sure. Thanks! Quote
jeremy Posted August 17, 2004 Report Posted August 17, 2004 just recharge it and get it over with Quote
Canada Posted August 17, 2004 Report Posted August 17, 2004 Does it still smell when the temp is on full cold? If so, you've pry got some nasties growing on your evaporator.....its dark, cool, and damp afterall. Quote
DiscoStudd Posted August 17, 2004 Report Posted August 17, 2004 Your A/C system has nothing to do with your heater.Mostly true, but the AC compressor does kick in (in winter when you're using the heat) when you put it into "DEF" (front defroster) mode. The reason being is to aid the heater in pulling down the humidity (fog) from the windshield. Have you ever noticed that Japanese cars have a separate button to activate the AC? You need to manually press the AC button on those cars to turn on the compressor when you're using the defroster in the winter. You'll notice a difference in the time it takes to defrost the windshield with and without using the AC compressor. GM's automatically switch on the compressor when you select "DEF." Quote
GP1138 Posted August 17, 2004 Report Posted August 17, 2004 I don't even have my compressor on the belt any longer. Your A/C system has nothing to do with your heater. How do you manage that? I didn't think there was a non-A/C belt, though I've only asked at Autozone so far.. that was before I revived my A/C system. Quote
digitaloutsider Posted August 18, 2004 Report Posted August 18, 2004 I don't even have my compressor on the belt any longer. Your A/C system has nothing to do with your heater. How do you manage that? I didn't think there was a non-A/C belt, though I've only asked at Autozone so far.. that was before I revived my A/C system. There's not a belt made for the Non A/C car since they use the same belt. There's simply a dead pulley in place of the compressor pulley. I simply took my old belt around the accessories and held up the slack, measured it, and headed off to AutoZone. Quote
midnight rider Posted August 21, 2004 Report Posted August 21, 2004 Get a retro fit kit for your ac and don't look back. Quote
