Nick1234 Posted August 16, 2004 Report Posted August 16, 2004 im looking for a 12 volt source only when the ignition is on for my car alarm. Quote
tloftus Posted August 16, 2004 Report Posted August 16, 2004 Car stereo? Ignition? http://www.the12volt.com Tom Quote
cryptnix Posted August 16, 2004 Report Posted August 16, 2004 i am not much help saying this but perhaps you should go and pickup a haynes manual ... that helped me install mine. sorry, for not much help but it'll save you with other questions that you may just feel wierd in asking because you think you should know it but you don't Quote
jeremy Posted August 16, 2004 Report Posted August 16, 2004 manuals are a definite help........... Quote
Manny Posted August 17, 2004 Report Posted August 17, 2004 I got this from http://www.bulldogsecurity.com/. They have wiring diagrams for most cars. LUMINA / EURO 4-Door and 2-Door / Z-34 1990- 1994 WIRE/ COLORS/ LOCATION 12 VOLTS CONSTANT RED/ IGNITION SWITCH HARNESS IGNITION 1/ PINK (+)/ IGNITION SWITCH HARNESS IGNITION 2/ DARK BLUE/WHITE (+)/ IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 1/ ORANGE (+)/ IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2/ VIOLET/WHITE (+)/ IGNITION SWITCH HARNESS STARTER/ YELLOW (+)/ IGNITION SWITCH HARNESS PARKING LIGHTS/ (+) BROWN/ at HEADLIGHT SWITCH or low in DRIVERS KICK PANEL DOME LIGHT/ WHITE (-)/ at HEADLIGHT SWITCH or low in DRIVERS KICK PANEL POWER DOOR LOCK/ LIGHT BLUE/ in DRIVERS KICK PANEL (TYPE "A") POWER DOOR UNLOCK/ BLACK/ in DRIVERS KICK PANEL (TYPE "A") TRUNK RELEASE/ BLACK (+) /at RELEASE SWITCH TACH SENSOR/ PURPLE/WHITE or WHITE/ at COIL PACK on ENGINE BRAKE/ WHITE or LIGHT BLUE (+)/ at SWITCH ABOVE BRAKE PEDAL HORN/ BLACK (-)/ at STEERING COLUMN HARNESS Quote
